2001 V70 2.4T ignition coil replacement tutorial
coilV70 Ignition coil replacement with good photos. Can be used for other models.
It was very obvious that something was not right; the engine ran rough, the steering wheel was shaking and the CEL came on blinking. To me it felt like one of the cylinders was not firing and plugging in the code reader confirmed my suspicion…P0305 “Cylinder 5 Misfire Detected”. OUCH
2001 V70 2.4T bad ignition coil replacement…
Date February 18, 2010
2 responses to “2001 V70 2.4T ignition coil replacement tutorial”
  1. Bill says:
    Do i need a gap before install Iridium spark splugs for 2002 s60 T5?
    Do you recommend Platinum park splugs better than Iridium spark splugs?
  2. chen says:
    I read this tutorial. Got a Engine Check at a local parts store, bought the coil and replaced it. The work it self took 20 min. Now my v70 is working great again. Thanks for your time and effort in posting this with photos it was a great help.
