Volvo Repair Database: Everything
This is the BIG list of repairs for every Volvo made in the last 30 years... Currently over 1500 Volvo problems, fixes, experiences and repairs.
February 13, 2016
Big Brakes on Small Wheels
MVS Volvo Forums member Nevada1906 not only installs a 302mm big brake kit on his 850, he shaves the calipers down so they’ll fit in his 16-inch Columba OE wheels. He documents the whole upgrade. Then he follows up years later on how it’s working. Here’s the story: After asking around on this site, I […]
This was posted in
February 13, 2016
Engine oil cooler line replacement DIY
MVS Forums Contributor Jason (jreed) blasts out a beautiful, detailed, downloadable DIY on replacing oil cooler lines on a Volvo 850. This DIY is likely applicable  for any Volvo P80 model. “The lower cooler line (lower = the one that goes to the lower inlet on the radiator) had developed a very slow leak at the […]
This was posted in
February 10, 2016
1993 940 Turbo Wagon For Sale, 33k Miles, $6850, Denver
http://denver.craigslist.org/cto/5439326925.html condition: like new cylinders: 4 cylinders drive: rwd fuel: gas odometer: 32850 title status: clean transmission: automatic 93 Volvo 940 turbo Wagon, only 33,000 miles, 2 owner, local car with all records at local dealership, Gold with Tan Leather,Sunroof, Heated seats, great tires, Just serviced. Cloth and weathertech mats, amazing Condition $6,850.00. The usual […]
This was posted in
February 5, 2016
Axle Death Click Click Click
Are you hearing a click sound from your front wheels? That’s the CV joints dying. They exist on front-wheel drive and AWD vehicles so that you can turn your front wheels. It’s a way — “articulation” — to get power from the engine to the wheels. You can either replace the axles (“half-shafts”), or if it’s not too late, you can re-grease and re-boot your existing axles.
This was posted in
February 5, 2016
AWD Versions of the 850 & V70
Ever wonder about the AWD peculiarities of the Volvo 1990s 850/S70/V70/XC70 cars? Which P80 models were built with all-wheel drive? MVS Volvo forums member Jazzop asks “Lately I’ve been curious about the AWD versions of the 855 & V70, but I haven’t found much in the way of FAQs/wikis explaining the model differences. Perhaps someone […]
This was posted in
February 4, 2016
Throttle Body vs. New MAP Sensor
This thread documents that the P0106 code is often resolved by throttle body cleaning, not MAP sensor replacement. Saves users about 250 USD. Specific to the NA 2003 and 2004 Volvo P2 models. jkatz: Two years ago I bought a 2003 V70 FWD (no turbo) and I was getting an intermittent CEL that would come […]
This was posted in
January 27, 2016
Which is Better? 13G, 13T, 15G Turbochargers
Confused about turbos for Volvos? If 13G, 13T, 15G, 16T, 18T, and 19T make you think of womens’ dress sizes, this post will help you understand what fits on your Volvo and why.
This was posted in
January 18, 2016
Codes from the ECU without the dataconnector thingy?
MVS Volvo Forums member -wj- has a 1996 Volvo 850 and needs to read the codes. “Can I get the ecu codes from the ecu without the normal dataconnector thingy? As in, can I connect a led/12v bulb to 2 pins on the ecu, and get the codes? edit: I’ts the motronic 4.3 one by […]
This was posted in
January 15, 2016
XeMODeX is a MVS Sponsor!
We’re proud to announce XeMODeX is partnering with this site to bring all of us information and Volvo troubleshooting solutions. XeMODeX cut its teeth developing and marketing a fix for Volvo’s ETM fiasco with their in-house developed contact-less potentiometer ETM. This announcement means XeMODeX’s ad appears at the top of MVS pages. Please let them […]
This was posted in
January 8, 2016
Fix a Rusted Exhaust on a Volvo
Need to fix a rusted exhaust on a Volvo? MVS contributor xHeart documents fixing his rusted, broken, leaking exhaust on his Volvo. This saga included a Class A fiasco on the part of Parts Geek shipping mislabeled and dented exhaust, then shipping an exhaust for a completely different Volvo. What a mess. The two ends […]
This was posted in
January 4, 2016
Should You Buy a 1998 V70 R with High Mileage?
Should You Buy a 1998 V70 R with High Mileage? Longtime MVS member and Volvo guru precopster asked, and answered, this very question. Note this car needed a good deal of engine work. Bottom line is $2,000 asking price for a car with 380k kilometres and a head that’s been removed with bent valves. Looks […]
This was posted in
December 18, 2015
98 V70 T5 Replacing the Coolant Hoses in Pics
You’ll want to remove your air cleaner box and also the duct pointing to the front part of the car. The air cleaner is set in with some tabs into a rubber retainer. Just pull up and to the passenger side to get it out. There were a few connections that need to be removed as well. Finally, tie the accordion air duct out of the way so that you’ll have a clear view. They are already out in this picture. I just highlighted where these parts used to be. It really opens up the area.
Standing on the driver side, you can look are clearly see the large hose (lower radiator hose) where it connects to the neck into the engine block. You can also see where the heater hoses go into the firewall. The Lower radiator hose is not too hard to access at this point. Loosen the clamp (above the yellow arrow in the picture) and pull it off. The other end is on the bottom of the radiator on the driver side. You’ll have to remove the lower engine cover plastic to get access to that.
This was posted in
