Volvo Repair Database
Ball Joint/Control Arm Survey
Control arm brand advice
“I just replaced both A-arms with the $38 ones from FCP. Considering it only takes less than 30 minutes per arm to change, I don’t care if they only last 1-2 years.
Also, I’d like to hear from the group that has bought the cheaper version that their a-arms are still going strong after 2-5 years? You always hear about the failures but rarely do people comment when nothing goes bad.”
Ball joint/control arm survey
  1. Driveshaft Knuckle Came Out
  2. Grease on CV joint 2002 V70XC
  3. Volvo 940: new ball joints, sway bar, end links, bushings
  4. School me on inner tie rods please
  5. Weird steering and braking problem
This entry was posted in Automotive Parts & Products Review, Saving Money, Suspension, Tires, Wheels, Springs, Struts, Control Arms, Tie Rods and tagged , , , , , , . Bookmark the permalink.
