Volvo Repair Database
Beyond OBDII – Small, Dedicated, Aftermarket Onboard Computers
It’s time to let go of the limitation our tiny-screen phones and limited-character dedicated OBDII devices. Imagine pulling into your garage, and when your new onboard aftermarket computer is triggered by proximity to a WiFi node in your garage, the data from your recent outing is sent to your home Mac or PC, and all parameters for the drive are processed into a neat report that may let you know before a code is set that your thermostat is likely getting a little long in the tooth.
The report is emailed to your email account, and arrives at your phone (and your 14-year-old’s phone, because s/he is next in line to your Volvo and wants to ensure you’re treating it right) before you turn the car off.
Arduino OBDII display - isn't that beautiful?!
Beyond OBDII – Small, Dedicated, Onboard Computers
  1. Breakdown of the DTC in OBDII
  2. What OBDII Scanner Should I Get?
  3. Reading OBDII Codes: 1997 and Newer
  4. Glove Box Fix #1 – The Small Hole Method
  5. Small Rust Spot Near Trunk
Tags
Bookmark permalink
