Buy a New Transmission or Rebuild: 2001 V70
What to expect when you have a 2001 Volvo transmission (known for failures… early and often) replaced by a dealer.
  1. Is it worth it to replace or have the transmission rebuilt?
  2. Would a new transmission going back into that year and model resolve all those issues?
  3. Will these issues plague the car forever?
  4. Would the transmission issues fry the motor?
  5. If I spend 2 or 3 grand and replace the tranny and maybe a little more to replace the computer is this lemon worth saving?
Should I buy a new tranny, have the old one rebuilt, or say
Forum views 14373Forum replies 23
Date May 19, 2011
3 responses to “Buy a New Transmission or Rebuild: 2001 V70”
  1. Rey Abeng says:
    I just bought a V70 XC AWD Cross Country for a steal because it has a transmission problem. I drove it in the interstate for a test drive to work (30 miles each way). All started fine until about 20 miles and the digitals on the dashboard for the D “Drive” disappears and just a dash line show up (also the temperature indicator is not calibrated or just going out already.) Can’t do the manual shift nor the cruise control. From stop to go, it hesitates but when it picks up speed, it is just fine. At around 25 miles to a complete stop, then go at a traffic light, it feels like it is stuck in either 3rd or 4th gear. My question before I dive into transmission replacement, is it possible to have the tranny oil pan dropped so I can replace the following: oil filter (if there is one), oil pan gasket, and ofcourse the oil, and maybe that the filter is clogged or that the oil has not been changed yet since the mileage of the vehicle is over 200k miles already. Will I be able to do the OBD myself to get the message removed once I’ve done the tranmission oil change?
  2. Robert Casey says:
    Rey, I have a 202 V70XC (owned since new). The first thing that you need to do is completely flush the trans fluid. You can do it yourself. I used the kit that IPD sells ($20 for tubing and connectors). It can be quite messy and it is difficult to pour fluid in as fast as it comes out at the radiator trans cooler hose ends. My car had 60,000 and the fluid looked like red tinted old motor oil. Tremendous shifting improvement!!! I spent around $130 on fluid. I would consider having the dealer do it! After 16 qts and one spilled, I still ended up low on fluid later.
    Secondly, this Volvo was designed to shift into a semi-neutral when you come to a stop to save gas. That is the lag that you experience on accelerating from a stop. It will improve with a fluid exchange. The dealer has a software update for around $160.
    I don’t know about the electronics. It might be completely separate.
  3. Brittany says:
    I have a 1996 volvo wagon, ive been having issues with the transmission ( automatic) until it gets up to about 35-40 mph its “putting”, and after about a week of that, the check engine light came on today. it has about 180,000 miles on it and has been pretty well taken care of, should i bring it to get a transmission flush, or is it possible that could do even more damage
