of 53
Body, Trim & Exterior
Exterior bits that make our Volvos pretty and functional: Body, Exterior Trim, Wipers, Glass, Bumpers, Mudguards, etc.
August 25, 2015
Water drain plug locations? 1999 C70 convertible
MVS Volvo Forums member JsinnC70 I am having a terrible time finding any info on the locations of the water drain plugs that are in the roof storage bay. My top is broken and will not go down. Is there any way I can access and clean the water drains? If so, how? MVS Volvo Forums […]
May 18, 2015
V90 Fitting Rear Mudflaps
MVS Volvo Forums member Martin Calva details his attempts to find the right Volvo part number, and install rear mudflaps on his V90.
May 12, 2013
How to Remove Badges
A little heat, a little dental floss, and a steady hand will do the trick.
February 5, 2013
DIY: 1998 S70 Hood Cable Replacement
If you keep any car long enough, chances are the hood cable will break at some point. Mine just broke the other day. New Volvo Cable for my 1998 S70 is Volvo PN 9444027, $36 at dealer.
Only after I did this job that I realized that this can be done for $3 using a bicycle cable with diameter approx. 1.0 mm (and much less time than because you remove nothing doing it this way)!
July 10, 2012
Given Up on your Headlight Wipers Yet?
For those with headlight wipers, have you given up on them? Vote in our poll.
