Problems & Fixes: Volvo S70 & V70, 1998-2000
Volvo S70 & V70 opinions, advice, repairs, maintenance, tutorials and more
October 5, 2016
Meyle Outer Tie Rod After Approx. 12 Months
Meyle Outer Tie Rod Followup MVS Contributor theWIFES_S70 (Marco) follows up after about 12 months on the status of a Meyle outer tie rod. When folks tell you not to buy something on her, they’re telling you because they care. Meyle Left Outer Tie Rod There’s a reason why it costs half the price […]
See this post
September 20, 2016
New ETM Dead out of Box
MVS Contributor precopster ran into a frustrating problem: a bad Magneti Marelli ETM… a new ETM dead out of the box. As if Volvo owners didn’t have enough trouble with 1999-2002 Volvos with failing/failed electronic throttle modules, now we have an example of a brand new ETM failing… right out of the box! See the MatthewsVolvoSite ETM […]
See this post
September 19, 2016
S70 Door Thinks It’s Always Open – Quick Fix
Driver Door Lock Shim Does the Job When your Volvo’s door thinks it’s open even when it’s closed, that’s one annoying problem. Here’s a simple, cheap fix that is appropriate for the age/value of the car. (Plus, I have a dark suspicion this part would cost way more than $100 at a Volvo dealer.) Problem: […]
See this post
September 18, 2016
AC Clutch Gap Magnetic Fix – Breadclip Alternative
MVS Contributor coflynn comes up with a brilliant and different approach and fix for the AC clutch gap problem, which is commonly fixed with the classic AC bread clip fix. See images from Volvo that show the AC clutch. He came up with an AC clutch gap magnetic fix. My A/C has been dead for a while, and […]
See this post
September 15, 2016
P80 Wagon hatch dimensions
MVS Contributor j-dawg: I need to load a ton of junk into my car soon, and I couldn’t find any info on the intertubes, so I measured its cargo area dimensions and put them in this picture. My car has basically no rear cargo options, eg: grocery nets, cargo bay cover, dog cage, third row […]
See this post
