Problems & Fixes: Volvo Tips
Tips, tricks, general Volvo information for owners
July 3, 2016
Control Arm Bushings – Buy Whole New Control Arms?
MVS Moderator Made In Japan wonders out loud if it’s better to buy control arm bushings and use a press to press them into the existing control arms, or say ####-it and buy new control arms. MVS Contributor oragex sums it up nicely: Most people agree that installing these bushings is a PITA. Being stubborn, […]
See this post
May 26, 2016
Pull the Head the Easy Way – Volvo 5-Cylinder
MVS Contributor jpgurley shows us how to pull the head of a Volvo 5-cylinder the easy way, with a documented outline of his steps: I am certain that both Volvo Service Manual and ALLDATA tell you how to do it the hard way. To use their methods, you would want a a lift and lots […]
See this post
December 6, 2014
Pro Tip: How to Store a Car
MVS Volvo Forums Contributor mecheng documents his 2-year storage efforts of his 1998 S70: After successfully storing a car for 2yrs with no issues, I can say bits and pieces of the info given is correct. Yes, make sure you run the stabilizer through the engine and not just dump it in the gas tank. […]
See this post
September 12, 2013
Tune Up & Engine Bay Basics
New to DIY’ing? Start here. These are wonderful iPD overview videos for the novice DIY’er. The video’s host goes over where parts are in the engine bay, what they do, and why they’re important. Tune Up Talk 2001+ models Tune Up 850/70 series models Tune Up Basics for Volvo 200, 700, and 900 […]
See this post
August 15, 2013
Battery Capacity
Does a battery with a too-large capacity for the vehicle cause damage? MVS Forum member tjai had the battery in an S60 replaced with an 800CCA three years ago and has been experiencing electrical issues ever since including power seat operation and a/c flow.  A mechanic explained that a battery with a larger capacity than […]
See this post
