April 27, 2012
Charcoal Canister, Fuel Pressure Regulator, Purge Valve, P0440
All about the intricate relationship between these elements of your Volvo: EVAP codes, Charcoal Canister, fuel trim, and three way unit with pressure regulator.
EVAP diagram
Bypass charcoal canister?
One response to “Charcoal Canister, Fuel Pressure Regulator, Purge Valve, P0440”
  1. cindy says:
    have a problem with my volvo 850 turbo import no fuel coming through, car will start sometimes but wont idel, and the air hoses to the turbo have slight bit of oil coming out of joins. what would the problem be and how to fix
