Here is a write-up on ’93-’96 ABS trouble codes. Like on any “Mode” change with the diagnostic box under the hood, press the button two times for mode two and 4 times for mode 4. I hope that this helps someone. Oh, and always, Victor Rocha who is a member here can rebuild your ABS module if that’s your problem (it is over 90% of the time with faulty ABS functioning).
’93-’96 850 ABS Trouble Codes
This entry was posted in Electrical, Battery, Fuses, Relays, ECU, Starter, ABS module, Alternator, Modules, Volvo 850. Bookmark the permalink.
Register
Search
Help
my son has a 1995 850GLT doesn’t start, has no spark when we tested it . checked coil reading were good. cranks good but no spark. so what else can i check,is it my ecm.
