Volvo Repair Database
Fuel Pump Relay Repair 2
Comprehensive how-to repair the troublesome fuel pump relay
So when my cousin’s S70 started stalling, we looked at several possibilities we first thought fuel pump. Its been 130K, so its probably toast by now. But I decided to take the relay out of my 850, which in fact was different (one extra pin and yellow colored relay box, plus different part number) and put it in his car. His S70 no longer stalled and the problem went away. So I took his relay, opened it up and proceded to remove the capacitors.
I ordered high grade capacitors to be installed in its place. I especially had trouble finding the right one for the silver one that is shown, because its size was unique and not easy to find. Which lead me to think, why was this capacitor so unique? It doesn’t look like any normal capacitors like the one next to it… something’s up.
fuel pump relay
I suspected that this was some sort of high density capacitor (perhaps a standard capacitor of the same value didn’t fit), but this is no longer a problem since time has past since this was constructed and capacitor technology had advanced (smaller and even better values). Once I removed them and put the new parts in, I decided to crack open the capacitor.
  1. Fix your own fuel pump relay
  2. Fuel Pump Relay Repair
  3. How To ID The Fuel Pump Relay
  4. How to Remove Fuel Pump
  5. Replacing an Air Pump – Repair Notes
This entry was posted in Electrical, Battery, Fuses, Relays, ECU, Starter, ABS module, Alternator, Modules, Fuel Pumps, Gas Tank, Fuel Supply, Fuel Filter, Fuel Lines, Fuel Injectors, Volvo 850, Volvo C70, Volvo S70 & V70, 1998-2000, Volvo XC70 & V70XC and tagged , , , , , , , . Bookmark the permalink.
