January 8, 2006
Coolant Flush How-To
I also flushed the cooling system with newe Prestone. Pretty easy: 1.13 mm wrench for the engine drain plug (located just above the driveshaft, on the right and rear side of the engine)…
Tags
2 responses to “Coolant Flush How-To”
  1. Ron says:
    the “Read the rest..” link above is not working (it references a non-existent anchor tag on the tips.php) and I’ll be d*mned if I can find the article to which it is supposed to be pointing.
    Thanks
  2. Matt says:
    Fixed. Thanks for reporting this, Ron.
