You will see a black plastic cover with a single torx screw holding it down. Unscrew, remove plastic. You will now see the intake, the throttle body and the throttle wheel. Disconnect the intake from the throttle body…
How To Clean Throttle Body
This entry was posted in Engine, Engine Internals, Turbo, Wastegate, Air Delivery, Airbox, Air Filter, Camshaft, Valves, Head, Pistons, Volvo 850. Bookmark the permalink.
Register
Search
Help
My Volvo S80 T6 1999 is hunting when in neutral, I have tried the Mass Air Flow Meter but this did not work, cleaned the throttle body, has anyone other ideas?
