IPD saleVolvo PartsVolvo Salvage: Used Volvo Parts and Over 50 Years ExperienceSouthern Vo Vo sells genuine used Volvo parts
PCV cleaning/replacement
If you have positive crankcase ventilation (PCV) bogging down your ride indicated by oil blow-by on your oil filler hose or smoke coming from your dipstick tube, now is the time to replace or at least clean your PCV system. Without proper maintenance, you could be damaging your engine seals without knowing it.
Here is a write-up from another site, but really excellent with pictures!
Regards,
MIJ
This entry was posted in Engine Volvo 850 Volvo C70 Volvo S70 & V70, 1998-2000 Volvo XC70 & V70XC
