'98 S70 Wiper Relay, Wiper Park and Blown 50a Fuses
dhmartyn
Postby dhmartyn » Tue Mar 27, 2007 1:05 pm
Hi, all. New to the forum, and new to Volvos as well. Bought a used '98 S70 GLT Turbo in January. Need to do several of the familiar fixes (i.e. Oil Trap, Oil pump).
Strange thing happened recently, though. I blew the 50a main fuse for the interior fuse box 2 or 3 times. It was always raining/snowing, and I swear I think it occured when the wipers were on and I turned the steering wheel hard to the left. Wiper blades would hesistate (maybe that was just the first thing I noticed), then headlights, radio, ECC, wipers would all cut out.
Well, now I have a different problem. Last time the wipers hesitated, the 50a fuse didn't blow. Instead, the intermittent wipers don't work, and the wipers don't park when I shut them off. They just stop wherever they are on the windshield when the wiper switch is turned to the off position. The wipers work normally in the low and high speed position, though.
As I understand it, the intermittent wiper is a function of the relay, so that would appear to have gone bad. The wiper park is a function of the wiper motor, so that would appear to have a problem as well.
I am ordering a new relay. I'll try that first, but I doubt that will have an effect on the wiper park function. Or will it? Or until I find out what is causing this electrical problem, am I just going to continue to fry the relay and motor?
Any suggestions, or experience with this problem? Thanks.
David Martyn
'98 S70 GLT Turbo
zenmervolt
Postby zenmervolt » Tue Mar 27, 2007 5:15 pm
Wiper park should be a function of the relay as well. It's typically the same circuit that controls intermittant. The parking issue is the relay, not the motor.
I would, however, check the wiper motor to see how much current it's drawing. It's possible that it's having some issues and drawing excess current, which would both cause the fuse to blow and cause the wiper relay to burn out.
'98 Volvo S70 T5 SE
'86 Porsche 951
'76 Porsche 914
VolvoBeginner
Year and Model: 1999 V70 N/A
Postby VolvoBeginner » Wed Mar 28, 2007 7:40 pm
dhmartyn,
Where did you get the relay from?
I have a problem with the Wipers Park like yo do. The intermittent wipers work but they stop wherever they want... I was told that this is a motor problem. But I still think this is more relay related, so I want to try with the relay first.
thx
1994 Volvo 850 Wagon (N/A) - sold
1999 Volvo V70 (N/A)
dhmartyn
Postby dhmartyn » Thu Mar 29, 2007 1:51 pm
Haven't gotten one yet. Just ordered from QuickBrick Motorsports. They have a $39 programmable intermittent relay. Can't seem to find any kind or relay for this locally, so I just figured I'd order online.
Still having the problem of when the wipers on and I turn the steering wheel hard to the left, the wipers stop on the windshield, then eventually start up again. Wondering if there is some short in the wiring in the steering column causing this. I really can't think of another logical reason why this would happen.
David Martyn
'98 S70 GLT Turbo
VolvoBeginner
Postby VolvoBeginner » Thu Mar 29, 2007 2:57 pm
Thanks,
I will get one anyway as the "programmable" feature of that relay will update the system. Even if it is motor problem for a fact it won't be money in the drain...
dhmartyn
Postby dhmartyn » Sun Apr 15, 2007 10:54 pm
Put in the new QBM relay, which fixed the wiper park and intermittent problem. Then it fried again when I made a sharp turn to the right. Had to be something between the steering wheel and the wiring for the wiper.
It made no sense to me that it would be in the steering column, but I took it apart anyway. It wasn't there.
I removed the kick panel (the same panel that you remove to replace the wiper relay itself), and tucked in next the the steering U-connection (coming down from the steering wheel where it connects through the firewall) was the bundle of wires from the upper steering column. It's held in place next to the U-joint by a plastic tie. When I pulled it over, I discovered that the plastic tape that wrapped the bundle, as well as a bit of the insulation on the wiring in the bundle, had been worn off by that U-joint as it turned over the years.
I took a piece of plastic insulation from the cover of some 12-2 house wiring and laid it across the bare spot, and re-wrapped the whole area with plastic electrical tape. Then, used a plastic tie around it and another bundle of wires to pull it away from the U-joint. Now, just have to replace the relay and I'm good to go.
David Martyn
'98 S70 GLT Turbo
Year and Model: '98 S70 T5
Flag: United States of America
Postby MadeInJapan » Mon Apr 16, 2007 12:13 am
I bought a VW relay a couple of years ago for my Volvo that does the same thing that the QB one does so I have the old (non adjustable) relay for my wiper laying around. If anyone wants it, it's yours. Just PM or email me (email is in my profile).
VolvoBeginner
Postby VolvoBeginner » Mon Apr 23, 2007 1:43 pm
VolvoBeginner wrote:dhmartyn,
thx
Put in new relay, did not help. Found a great local shop specializing in Volvos with their own Volvo salvage yard. Got the motor for $35, put in and wipers finally work as they suppose to! 8)
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot], configsys, RickG and 44 guests
