Squeaky dash - solution
yankinwaoz
Postby yankinwaoz » Wed Nov 28, 2007 12:55 am
Greetings all.
My Volvo mechanic gave me an easy solution to my squeaky dashboard problem. I just did it (took about 1 hour), and it seems to have solved the problem. I'll post an update next week to see how long term this is.
This is for a 1999 Volvo V70. I think it should work for other models too.
The problem was a loud and annoying squeak coming from the dash on the passenger side. Sometimes it would go away. But then I would hit a bump and it would come back. I tried removing the glove box... no luck. It sounded like two pieces of plastic rubbing against each other. Similar to how a balloon sounds when you rub it. Very irritating!
He told me to tighten up 4 bolts on the firewall. He said that he would bet that I could get a 1/2 turn on each. These bolts hold the dash frame inside the cabin. I ended up getting 2 whole turns. Here is the procedure.
(1) Remove the wiper arms:
(1.1) Use a Sharpy or something to washable and mark where the wiper arms are. Just run it along the blade. This is so later you can put the arms back exactly where they came from.
(1.2) Remove the caps covering the nut on the wiper arms. There is a small notch on the arm. You can stick a small screwdriver blade in the notch and pop the cap off.
(1.3) Unbolt the wiper arms with a socket wrench.
(1.4) Remove the wiper arms.
(2) Remove the cowl over the wiper assembly:
(2.1) There are 5 torx screws holding the black plastic cowl over the wiper motor system. Remove them.
(2.2) Remove the long rubber trim on the top of the cowl
(2.3) Remove the short rubber trim around the fuse box.
(2.4) Remove the lid of the fuse box. There are 4 torx screws hold this down. You need to remove it to make room to slide the cowl back from the windshield.
(2.5) Unclip the the two rubber water drain hoses from the cowl. There is one on each side of the car.
(2.6) Carefully slide the cowl towards the front of the car. Just a few mm will do it, until it is no longer under the windscreen rail.
(2.7) Lift the cowl out and away.
(3) Unbolt the wiper assembly:
(3.1) At this point you will have access to the bay that contains the wiper system. On the right side there is a black box with a paper filter. That is the cabin air filter.
(3.2) You need to loosen up the wiper assembly in order to get to two of the bolts that need to be tightened. There are two bolts that need to be removed. One is on the edge of the wiper bar and goes into the vertical wall. The other is on a horizontal surface on the center of the car. Remove these bolts.
(3.3) Loosen the wire harness. There is a wire bundle that goes to the fuse box the also goes over the wiper assembly system, right at the center bolt that you removed. You have to open up that clips that hold the bundle down so you can move the wires out of the way.
(4) Tighten up the 4 bolts.
(4.1) At this point you should be able to move the wiper assembly aside enough for a socket wrench to get a clean shot at two of the bolts.
(4.2) Tighten down the 4 bolts with a socket wrench. They are on the vertical wall separating the motor bay and the cabin. They are really easy to spot since they are the only bolts in the area. I was able to get two full turns on all 4 of my bolts.
(5) Clean up the dirt and leaves.
(5.1) While I had that cavity opened up under the cowl, I took the opportunity to clean it out. There was dirt and leaves in there, which I vacuumed out.
(5.2) I took out the paper air filter and washed it. It was filthy. I should replace it, but I don't have a job or money right now. So I sprayed it off real good with a high pressure hose. A lot of dirt came out of it, and leaves and other plant life too.
(5.3) I also hosed off the cowl and cleared out the drain holes. They were caked with dirt and mud.
(6) Then reverse the process to put it all back together.
(6.1) Don't put the wiper arm caps back on until you have closed the hood and made sure the arms are where they are supposed to be. If you marked the angle in step 1.1, then this should be easy.
(6.2) Don't tighten down the bolts until you close the hood.
(6.3) Close the hood and test the wipers to make sure they clear the hood. If they are too low, they will hit the hood.
(6.4) Once you have the the arms at the proper angle, tighten the bolts and put the caps back on.
Well.... this makes me wonder how many other bolts on this 1999 Volvo need to be tightened up?
Year and Model: '98 S70 T5
Flag: United States of America
Postby MadeInJapan » Wed Nov 28, 2007 1:48 am
Thanks, yankinwaoz!
Just be careful tightening those...the anchors are plastic (what was Volvo thinking?) and can break. But good write-up none-the-less. I'm pinning it in the repair database section!
bekko
Postby bekko » Wed Nov 28, 2007 8:07 am
Is this a great forum, or what? Our '98 has had that squeek for at least seven years. It will make you crazy. You can jam a pencil between the windshield and the dash board to dampen it, but then the squeek moves to the other side.
-steve
-steve
hausmeister
Year and Model: 1995 850T5-R
Flag: Austria
Postby hausmeister » Thu Nov 29, 2007 6:05 pm
I did this 2 times already, but it's not a permanent fix, at least not for me :roll:
Noises come back after some time...
S70 '98 2L na manual Image || 850 T5-R '95 auto Image
yankinwaoz
No squeeks on 8 hour trip
Postby yankinwaoz » Fri Nov 30, 2007 3:54 pm
I drove the V70 from Santa Barbara to Tucson yesterday. 8 hours, and no squeak.
However, there is some creaking from the dash on roads that are bad. I suspect the creaking has been there all along.
I wonder if I should glue the bolts down?
hausmeister
Flag: Austria
Postby hausmeister » Fri Nov 30, 2007 8:43 pm
don't think so. The screws go in the lower dash afaik.
This summer I removed the upper dash in order to find what causes the noises, but couldn't really find anything. Made sure everything was tightend up.
Think the dash deforms over time...
I think the only thing that would really help is to fill the dash up with this http://de.wikipedia.org/wiki/Bauschaum (sorry, don't know what it's called in englisch)
But I'm not that desperate (yet) ;)
sixdown
Postby sixdown » Fri Nov 30, 2007 10:10 pm
hausmeister wrote:don't think so. The screws go in the lower dash afaik.
Bauschaum literally translate to building foam, which I assume means expanding foam which you can get in any hardware store. I wouldn't use it myself because it can break up and cause more annoying rattles. Not only that, it's messy when you have to remove the dash in the future.
1998 Volvo S70 N/A 75K Miles
Postby MadeInJapan » Fri Nov 30, 2007 11:38 pm
I agree. Felt strips is a much better/safer idea and I've read where people have used it successfully.
dobriduh
Postby dobriduh » Sat Dec 29, 2007 1:19 am
Thanks for the post
However, it took me forever just to read that :) I used some double-sided sticky tape to solve this problem. I located where the squek is coming from and put the tape in there. The awkard noise is gone but it does not look very aesthetic seeing the tape on the dash (its not that horrible) but thats a compromise I decided to make.
S70 1998 Automatic
hausmeister
Flag: Austria
Postby hausmeister » Tue Mar 25, 2008 8:44 pm
Hi guys.
some time ago my dash started rattling again - really annoying. I could see the dash bouncing around a bit.
This time I looked into the Haynes how it is mounted. I found there are 2 screws on each side near the doors, where the bottom of the dash is secured. They are hidden beneath a plastic guard.
I loosend the right side one and pushed the whole dash down as far as possible and re-tightend it.
Today I went for a drive, and it hasn't made a sound yet :shock:
I really hope this is kind of a permanent fix; anyways, if you have similar problems you might want to try that.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: MSNbot Media, scot850, theWIFES_S70, v-45magna, vcowens and 39 guests
