coolant temperature sensor for 98' S70 GLT
MelissaB.
Postby MelissaB. » Fri Dec 28, 2007 5:02 am
I am having a problem locating the coolant temperature sensor on my 98' S70 GLT 5-T. I did the OBD-II and it gave the code P10117- the C.T.S. I had the water pump replaced, timing belt, and serpentine belt replaced in Sept. 07'. Since then the CL light is on. I could really use a picture of where the sensor is located, all I could find was one on the thermostat housing.? Any tips, picts., etc. is GREATLY appreciated! :roll:
Thank You, Melissa
mileage= 155357
1998 Volvo S70 GLT
Flag: United States of America
Postby MadeInJapan » Fri Dec 28, 2007 6:07 am
The one on the thermostat housing is correct.
As you can see, it is at the end of the thermostat housing, right under the coolant hose that runs to the radiator.
You can find it here for $30 (same as the 850 water temperature sensor):
http://www.fcpgroton.com/volvo850cooling.htm or here for $25: http://www.ipdusa.com/Volvo-SV70-1998-2 ... -368-1345/
MelissaB.
1998 S70 GLT [color=red]temperature sending unit[/color]
Postby MelissaB. » Wed Jan 02, 2008 8:37 am
Hi, just wanted to let you know you that after replacing the "temperature sending unit" the car runs great! I thank you for your speedy reply. The picture was perfect.
1998 Volvo S70 GLT
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot], MattsS70, sleddriver, They_got_no_horns and 45 guests
