IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    obdII p0171, 1996 volvo 850 Non turbo
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby izcali » 14 Feb 2008, 23:30
    Hello, I have been working on my 96 volvo 850 for days without any success. I keep getting code: P0171 running lean.
    problem: P0171---- unstable idle---------The vehicle runs ok while driving but when I get to an intersection, the car sitting there at idle, the engines begins to idle up and down and then gets ok, and the check engine light is on.
    I have done the trying to fix the problem:
    Replaced the front O2 sensor.
    Cleaned the throttle system really good using a toohbrush.
    Checked the distributor.
    Replaced all the spark plugs.
    Check the fuel pressure with a reading of 44 PSI.
    Checked for any vaccum leaks spraying propane gas around all the hoses and found no leaks.
    Replaced MAF sensor and a few hoses around there including the trap valve.
    Using Premium gas 93.
    Cleaned the Idle Air Control valve and the two hoses that go in and out of it.
    Checked the vacuum hoses as well as the vacuum tree. Even the hoses under the thermostat on the intake manifold, and the one going to the fuel pressure regulator.
    THE CHECK ENGINE LIGHT KEEPS COMING ON AND THE IDLE IS STILL UNSTABLE.
    ANY SUGGESTIONS PLEASE!!!!!!!!!!!!
    izcali
    Postby MadeInJapan » 15 Feb 2008, 00:34
    I guess what you have left then is making sure your fuel filter is clean and then that you have enough fuel pressure. Other than that, the MAF could be bad to begin with or the 02 sensor. Did you replace with OEM parts?
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby izcali » 15 Feb 2008, 01:56
    I have replaced the fuel filter, and the MAF was an after market unit. But Would I be getting a different codes if in fact the MAF was going bad:
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    The code I am getting is p0171 and none of thew above.
    thanks
    izcali
    Postby Ozark Lee » 15 Feb 2008, 02:35
    The AMM/MAF codes can be deceptive and they will show up as O2 sensor range errors if the MAF doesn't quit altogether. It is a "goesinta" vs. "goesouta" thing. Many a time a MAF problem will throw an O2 sensor range error since it is trying to use the MAF as its benchmark to measure from.
    If you still have your old MAF around try to clean it and put it back on. Use electrical contact or MAF cleaner on it. Just spray it and let it dry. Don't scrub it or even touch it.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Previous: 1989 740 GLT
    Postby MadeInJapan » 15 Feb 2008, 03:18
    Another thought...if it is the MAF then just unplugging it and clearing the code and then starting your car will give you other trouble codes but not the one you were getting.
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: Bing [Bot], Google Adsense [Bot], Kel and 56 guests
