Front Struts and Rear Shocks Replacement 93 Volvo 850
justinfrim
Postby justinfrim » Fri May 16, 2008 7:39 am
I have a terrible clunking sound on my front end and my front suspension is basically shot anyway. Can anyone recommend the exact part list I need to make sure I take care of the clunking sound and get the new struts?
My rear shocks are not as bad. What would be the basics to replace these?
And how many hours in labor is typical for something like this?
Thanks in advance!
7 VII 7
Re: Front Struts and Rear Shocks Replacement 93 Volvo 850
Postby 7 VII 7 » Tue May 20, 2008 5:51 pm
justinfrim wrote:I have a terrible clunking sound on my front end and my front suspension is basically shot anyway. Can anyone recommend the exact part list I need to make sure I take care of the clunking sound and get the new struts?
Thanks in advance!
you need..
(reference - http://www.eeuroparts.com/searchresults.aspx?&carid=1820&cat=1033# )
FRONT
# - Qty
23 - 6
3 - 2
4 - 2
5 - 2
10 - 2
14 - 4
43 - 4
it is expensive but if you hear a clunking it is most likely your strut mounts (rubber #5) get OEM. that is the highest % of failing items in our suspension. so if you do not need to replace anything because they are fine... get the spring seats first
REAR
# - Qty
30 - 2
31 - 2
32 - 4
33 - 2
34 - 2
35 - 2
please anyone chime in with other parts
1998 S70 NA - 176k
Year and Model: '98 S70 T5
Flag: United States of America
Postby MadeInJapan » Tue May 20, 2008 10:20 pm
Clunking on the front can also be the sway bar end links (#11). Unless you're planning on doing a complete overhaul, start with this...the cheap stuff first.
MIJ 8)
justinfrim
Postby justinfrim » Wed May 21, 2008 5:39 am
FCP Groton as a front suspension kit with the following for $450:
* Left and Right Control Arms with Ball Joints
* Left and Right Outer Tie Rod Ends
* Left and Right Front Strut Assemblies
* Left and Right Strut Mounts / w bearings
* Left and Right Spring Seats
* Left and Right Sway Bar Links
* Left and Right Strut Dust Boots
* Left and Right Strut Rubber Bumpers
* Strut Mount Lock Nuts (six)
* Strut Bolts (four)
* Lock Nuts for above bolts (four)
How much would I be looking at in labor hours on that?
justinfrim
Postby justinfrim » Wed May 21, 2008 5:42 am
But they also have the following for $422: Which one do you think is the best shot in the dark considering I get the rear shocks as well here?
2 Complete (Left and Right) Front Strut Assemblies #8600901 manufactured by Sachs/ Boge
2 (Left and Right) Rear Shock Absorbers # 9173851 manufactured by Sachs/Boge
2 (Left and Right) Front Strut Mount Assemblies # 3546189 manufactured by SKF (Original Volvo Supplier)
2 (Left and Right) Front Spring Seats #8646713 List Price $33.67 each
2 (Left and Right) Sway Bar Links
Postby MadeInJapan » Wed May 21, 2008 10:52 am
I would call them...make sure NO SCANTECH products are thrown in the mix.
7 VII 7
Postby 7 VII 7 » Wed May 21, 2008 1:45 pm
MadeInJapan wrote:I would call them...make sure NO SCANTECH products are thrown in the mix.
I can verify that the set up that FCP has listed for under $500 does have SCANTECH parts... so no no no on that.
and if you were to get ALL of that installed at a shop.. it would cost an arm and a leg... you can do a lot of it yourself
1998 S70 NA - 176k
justinfrim
Postby justinfrim » Wed May 21, 2008 7:17 pm
Both packages have Scantech parts? I don't have any place to work on this myself (live in downtown city) so will be taking to mechanic. How many hours of labor should it be you think to replace struts/shocks/strut mounts/spring seats/sway bar links?
Thanks again everyone.
Sperry
Year and Model: 850 Turbo 1994
Postby Sperry » Thu May 22, 2008 1:59 am
I bought the FCP kit, and the spring seats lasted all of one month.
1994 850 Turbo Sedan. 202,000, and getting more experienced, not older. - sold
Postby MadeInJapan » Thu May 22, 2008 2:38 am
They probably had Scantech parts in the kit...like I said, call them and confirm. It's better to replace some parts for OEM parts that are Scantech and pay a little more...really!
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: BEJinFbk, Bing [Bot] and 35 guests
