Hood release cables for 1998 Volvo V70 AWD
holler1
Postby holler1 » Sun Aug 10, 2008 3:11 am
I need to replace both hood release cables, the cable from inside vehicle to driver's side latch and crossover cable from passenger's side to driver's side. I've tried for a couple of hours to find them online with no success. I'm wondering if someone might have the part numbers and/or have an online source. I'm 90 miles from the nearest dealer so prefer to order online if possible.
Also, if someone has installed a new driver's side cable, I need to know where it penetrates the firewall. One diagram posted by Bill of Durham seems to show it going through behind the wheel well liner (near the evap valve?). I'm hoping not to have to take off and replace the rivets in the liner unless necessary.
When I replace these cables, because of all the problems they cause, especially if they break, I'm thinking of also installing a couple of emergency release cables inserted through the latch release holes and hanging down from the latches inside the hood. That way if I have another cable break, I've got an alternate way in. It's impossible to manually reach the latches from the bottom of this vehicle- I have the scraped up arms to prove it.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
Flag: United States of America
Postby MadeInJapan » Sun Aug 10, 2008 9:20 am
I'm hoping the following diagram will give you the information you need:
instarx
Year and Model: V70 XC SE, 2000
Postby instarx » Sun Aug 10, 2008 6:17 pm
On my 2000 it goes straight down from the hood latch a couple of inches, curves back under the battery, under the air cleaner box, around the shock tower and into the firewall through the large grommet just to the rear of the shock tower.
2000 V70XC SE - 184k miles
Total repairs over past 8 years: $1,660 ($207/year) but needs a new angle gear.
28-31mpg highway; 17-21 mpg city - accurately measured
holler1
Postby holler1 » Sun Aug 10, 2008 8:26 pm
MIJ, that looks like it. Nice diagram, what is the source? I had a little time today, so I bought a generic choke cable kit from Advance Auto and modified the cable to make a crossover cable. The cable and sheath were both the right diameter. I cut the cable sheath to the right length, and bent the cable ends and filled them with solder. After a little adustment it fit and seems to work OK.
Instarx, that sounds the same as my routing but I couldn't see where the firewall penetration was. To avoid re-installing the drivers side cable sheath, I got a generic hood cable wire and put it through the existing sheath. I still need to connect it to the release handle but didn't have time today.
Thanks for the info.
JRL
Year and Model: Several
Postby JRL » Sun Aug 10, 2008 8:49 pm
Don't forget to adjust the hood latch (the left one) up so it has pressure on it, so when you pull the cable it takes very little effort to pop up
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
Postby MadeInJapan » Sun Aug 10, 2008 8:50 pm
That is from VADIS. I just use "print screen," then paste into a graphics program and save as a jpg file that I can upload. You can buy a VADIS DVD disc from someone who's reputable on eBay for about $40~50. It does come in handy for cars that are not covered in the 850 repair manual which can be downloaded from this site.
holler1
Postby holler1 » Sun Aug 10, 2008 10:44 pm
JRL - Thanks, will do.
MIJ - Thanks again. I saw references to VADIS but wasn't sure what it was. I looked in the 850 manual but couldn't find the hood diagram. I had seen one for an 850 on another thread from Bill of Durham but it was a different design.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot], kaneelschep, tryingbe and 38 guests
