Volvo 1996 850, problem is crankcase pressure and power lost
DWEames
Postby DWEames » Tue Sep 16, 2008 11:23 pm
I recently bought a Volvo from a friend, and was driving it away from New Orleans and Hurricane Gustav, and got about 25 miles out when I suddenly lost power and the engine started running rough. I'm on a long voyage to Montana to spend time with my sister. I had to get away from the hurricane so I putt putted out of town. I stopped to put fuel injector cleaner in, then tried in Shreveport to clean the idle air control valve. it is moving freely now. (everything I tried, I learned from this site) So naturally I started giving the car a tune up by changing the plugs, which were totally fouled. Each time I tried something, I would drive a little more. And the power was improving. I stopped in St. Joe to work a job for a friend, and drove the car around wih decent power. However it was still sounding like a motorcycle, and not back to full power. I changed the Spark Plug Wires (i'm on a budget, and that's why i'm doing this piece-meal). It still did not fix the problem. From Missouri I drove up through South Dakota, and the plains killed me, and apparently this Volvo I have grown to love. Wall, South Dakota is apparently the place where this kind of stuff happens. I changed the fuel filter because of the alchohol content in their gas here is apparently wrecking fuel systems. It will start now and I can rev up the engine in Park, while it is not smooth, it will at least raise the RPM's. I looked at the Timing belt, it's fine. I looked at and cleaned the MAF sensor. I just noticed a thread about an accelarator sensor. Is this something I should investigate. I need cheap solutions. OH, oil is coming up out of the oil filler cap, and dipstick. I've been reading up on PCV problems with this car. The local mechanic had a dire diagnosis about the crankcase pressure, and something he calls (blowby) Is this my problem, should I count on this costing many hundreds of dollars? Please help, my Volvo friends.
confused_al
Postby confused_al » Wed Sep 17, 2008 1:29 am
I would try something simple first, clean the "flame trap" (for n/a model only);
http://volvospeed.com/Repair/ftrap.php
In my case the cleaning along with replacing clogged elbow solved the positive pressure issue.
And check the Airbox thermostat, make sure its open to the fresh air side.
http://www.matthewsvolvosite.com/chat/p ... sc&start=0
Good luck!
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
vegasjetskier
Year and Model: 2010 Toyota Prius
Postby vegasjetskier » Wed Sep 17, 2008 1:38 am
You could try a bottle of Auto-Rx (http://www.auto-rx.com). If your ring packs are stuck (which might be causing the excessive blowby), this stuff might unstick them and reduce the blowby to a tolerable level.
Help this site: Amazon.com link, Tirerack.com link, Donate
Year and Model: Many Volvos
Flag: United States of America
Postby Ozark Lee » Wed Sep 17, 2008 1:44 am
Blowby is stuck or bad rings (or possibly the PCV system).
I wish I had known as you were tracking up I-29, I would have helped around KC.
What kind of spark plugs did you put in and what kind of plug wires did you use?
The proactive thing you can do is to buy a can of Seafoam from an auto parts store and dump 1/3 of a can into your oil. Drive it for a short while - I'm not sure what a short while is and the instructions on the can are silent. I would guess 100 miles or so would do it. Then change your oil and filter. The bummer is that in Montana I doubt you can find a Mann filter unless there is a local Volvo dealer. I have heard the NAPA gold filters are OK but I have never used one. Even if you wound up with a FRAM it will just mean clacking on startup until you can find a real filter.
It may or may not help but it can't really hurt anything.
JRL had great results after seafoaming his oil on compression. Good compression means less blowby. Hopefully Jim will jump in on how long to run the car with the Seafoam before the oil change.
You didn't say if you have a turbo or not. Particularly with a turbo, check all of the vacuum lines and the intercooler lines. The vacuum lines break / crack and the intercooler lines tend to just collapse under revs when they go south.
Is your check engine light on - if so get the codes read and post them back. The codes give us a lot to work with.
I'm glad you escaped Gus and clearly you were nowhere coastal for Ike.
A link to great pictures from Ike:
Ike Pictures - #11 is amazing
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
DWEames
flame trap and airbox thermostat
Postby DWEames » Wed Sep 17, 2008 2:00 am
Thanks Ozark, Vegas, & Al
This is not a Turbo, and I have over 100k miles. I would know exactly, but the odometer is broken. I cleaned the flame trap, which was full of gunk, and am now headed for the airbox thermostat. I have been suspicious of the MAF sensor. I looked at it, but didn't notice anything bad; one thread says that hot air can damage them, should I be looking in that direction? I hope that I can understand the directions for checking out this Airbox Thermo. Also I noticed one of the places the bolts holds the distributor on is cracked, and I have not checked out the distributor, rotor, etc...I'm about to download those instructions, and investigate. Because of the PCV issue I have had oil pooling up in the valve cover. I changed the spark plugs, spaced at .028, and have bosch wires (which said they were identical to factory).
I have a grey 1996 Volvo 850 with over a hundred k miles on it. I'm not sure because the odometer is broken.
DWEames
still broken
Postby DWEames » Wed Sep 17, 2008 8:33 pm
I looked at this airbox thermostat. I'm afraid my problems are more complicated. I have done some testing. I ran the car without cylinders 2 & 5. I had the code that said multiple misfire and system control misfire a while back. So there was no difference in performance when I remove the wires from those cylinders. In addtion to that I opened my distributor cap & it was filled will oil and crud from the spill over on the valve cover (PCV???). I cleaned it out best I could, but am worried that it could still be the problem? Does that sound like something that would cause the car to run very very slow until the RPM'S build? This part of Wall wouldn't have a new distributor cap until tomorrow and it's kinda pricey.
vegasjetskier
Postby vegasjetskier » Wed Sep 17, 2008 8:47 pm
Holy cow, you're lucky it was running at all. You might want to change the rotor at the same time. Have you been able to reduce the oil leak?
DWEames
Postby DWEames » Wed Sep 17, 2008 8:51 pm
I will. I scraped the rotor down, but am wondering if I scraped too much off. I could spend another night in town and wait for this cap. It seems likely that i have a bad distributor cap. I cleaned the flame trap thing out, but can't be sure until I try driving this thing a considerable distance. I just need to make it to a town 50 miles away that has more parts.
vegasjetskier
Postby vegasjetskier » Wed Sep 17, 2008 9:01 pm
You should be able to get it to run for 50 miles just by cleaning things up. Make sure you scrape all the crap off the electrodes in the cap - that's where the current flows through when the plug fires. And try to clean all the rest of the oil out of the cap so you don't get carbon tracking - that's when an alternative current path is created by carbon buildup and the electricity doesn't flow to the correct spark plug.
Postby Ozark Lee » Wed Sep 17, 2008 9:09 pm
You may have a rear cam seal leak. The distributor cap actually seals pretty well and I doubt that oil from the top of the engine got inside of it. Changing the rear cam seal is actually fairly easy is you can get one.
If your PCV is totally clogged up here was a creative way that one of our members dealt with it to get his car home from Washington DC to Manhattan, KS.
http://www.matthewsvolvosite.com/volvo-blog/2008/03/
I think the line to the jug was tied onto the dipstick tube.
'98 S70 T5
'96 850 N/A
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: 98s70, Ben850, Bing [Bot], Exabot [Bot], France850, Google Adsense [Bot], Jazzer, krenekj, Marty27, misha, polskamafia mjl, theWIFES_S70 and 38 guests
