Please don't use image hosting services like Image Shack. Here's why.
Having trouble logging in? Please delete http://www.matthewsvolvosite.com cookies in your browser. Here's how.
strut replacement- 2000 v70xc
mrscullini
Year and Model: 05 XC70, 08 XC70
Postby mrscullini » Thu Oct 23, 2008 12:13 pm
i've got an '00 v70xc se with 125k miles. i've got that noise from the front end which i believe is the spring seat. however, it looks like the bump stop is gone. i am referring to the rubber at the top of the strut tower in the engine compartment.
should i just replace the mounting hardware or replace the struts also while i am there? the damping in the front end seems fine but since i have to remove the struts to replace the hardware do i spring for the struts as well?
any insight is appreciated.
Year and Model: '98 S70 T5
Flag: United States of America
Re: strut replacement- 2000 v70xc
Postby MadeInJapan » Thu Oct 23, 2008 12:52 pm
At those miles, depending on how the car has been driven thus far, the struts are probably gone. Even though it seems to be dampening correctly, you'll notice a huge improvement if you change them out. I know that I did on my S70 at 100K miles. That said, if you have the money, I would do it all...and on both sides. If one side has gone, it won't be long before the other side goes too. I ordered all of my parts from www.shox.com and have been well satisfied. You don't find the spring seats and strut mounts (bumps) here but if you call them, they can send them to you as well....just make sure you don't get any ScanTech parts- ask them and ask them again to double check. These parts look fine and are cheap but wear out quickly (some have said, within a year).
mrscullini
Postby mrscullini » Thu Oct 23, 2008 1:18 pm
MadeInJapan wrote:At those miles, depending on how the car has been driven thus far, the struts are probably gone. Even though it seems to be dampening correctly, you'll notice a huge improvement if you change them out. I know that I did on my S70 at 100K miles. That said, if you have the money, I would do it all...and on both sides. If one side has gone, it won't be long before the other side goes too. I ordered all of my parts from http://www.shox.com and have been well satisfied. You don't find the spring seats and strut mounts (bumps) here but if you call them, they can send them to you as well....just make sure you don't get any ScanTech parts- ask them and ask them again to double check. These parts look fine and are cheap but wear out quickly (some have said, within a year).
thanks mij.
i had planned to do both sides. i figured i would get parts from groton, any reason i shouldn't? i am pretty happy with their service.
Postby MadeInJapan » Thu Oct 23, 2008 2:12 pm
Fine...just stay away from ScanTech like I said. I mentioned Shox because when I bought from them, they were actually cheaper than groton. Compare and save!
JRL
Year and Model: Several
Postby JRL » Thu Oct 23, 2008 3:45 pm
If the pocketbook allows, install everything NEW and use VOLVO OEM, never use Scan Tech or any other aftermarket pruducts except the struts themselves.
I would do new struts, new spring seats (use either Volvo XC90 seats, they're better, or IPD's seats for those).
New steel spring plates if it looks the least bit funky, new control arms and while you're there check the inner and outer tie rods.
I just rebuilt my 2000R's front end completely and it literally feels like a new car.
I use Konis but that may be too expensive for you, next choice would be Bilstein tourings, last choice would be Sachs OEM struts
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
larryh
Postby larryh » Fri Oct 24, 2008 1:50 am
JRL wrote:If the pocketbook allows, install everything NEW and use VOLVO OEM, never use Scan Tech or any other aftermarket pruducts except the struts themselves.
exactly. what he said. only I would add sway bar end links to that list. and i would just change the tie rod ends unless they've been done. Your car will drive sooo nice.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: erikv11, jimmy57, rguzz, RigsPGT and 46 guests
