Front door window track R&R (problem with Volvo part)
wheelsup
Postby wheelsup » Wed Nov 12, 2008 3:17 am
I replaced my front drivers window track today, it was clunking while opening and closing the door. The track has a bracket that broke due to what looks like metal fatigue and replacing it was harder than it needed to be. I suppose I could've gone to a junkyard but called around and none in my area had what I needed and one even charged a $50 minimum...so instead I bought it from the dealer for $22.
First I took the door panel off, it comes out very quickly and easily. The access to the track is behind the black plastic insert near the back part of the door above the handle arm mechanism.
Looking inside the door, the red outlines the window track:
To take the track out it requires one torx be removed:
Once that is removed you can pull the track down from the window trim liner itself. In my case that torx bolt just held the bracket...and the track had already fallen down into the door.
You can see old vs. new. Immediately you notice the new track doesn't have the nut welded into place, which is odd it came from the dealer like that, and I double checked it was the right part for my model year. No idea why Volvo makes them like that...
To get the new track to work I didn't have any nuts that were that size, so I re-used the old bracket. Also there isn't much room in the door so maneuvering a ratchet back that would be tough, this method is "self tapping".
Here's a test fitting:
I taped the bracket on in order to install it. You basically have one shot, if the old bracket fell down into the door it would be lost forever.
Here it is lined up after putting it in, I just re-used the old torx bolt that I took off and added some loctite onto it.
Hopefully this helps someone else, it took me awhile to figure out how it was installed, I couldn't find it in the Haynes. I know there is a lot of talent on this board and you guys can do it with with your eyes closed but it took me an afternoon! :)
-matt
Flag: United States of America
Re: Front door window track R&R (problem with Volvo part)
Postby MadeInJapan » Wed Nov 12, 2008 5:02 am
Thanks Matt...this is now in the repair database.
-MIJ
cjaama
Year and Model: 1996 850
Postby cjaama » Mon Dec 07, 2009 6:47 pm
i recently had to make the same repair and found it helped access by removing the red light on the door.
RobTheModd
Year and Model: s70T5 1998
Postby RobTheModd » Mon Dec 07, 2009 7:14 pm
I have a gut feeling I am going to have to do this soon, as my window is making a loud clunk sound *almost like dropping* once it is all the way down in the door...
But I could be wrong, Any ideas>
FloridaVolvoCommunity Owner, MatthewsVolvoSite Lover
tom39
Year and Model: S70 T5, 1998
Postby tom39 » Tue Dec 08, 2009 1:14 am
Had the same issue about a month ago. Seems like those tracks have a built in lifespan.
Wish I had your picks then, it would have made my life a lot easier at the time. Anyway I went the cheap way out and mig welded mine back together and reinstalled.
BTW: Nice job on the write-up
TOM G.
98 - S70 T5 Silver 230k/mi
11 - S80 Silver 96k/mi
Wagonizer
Year and Model: 94 850
Postby Wagonizer » Fri Mar 19, 2010 11:35 pm
Hi,
I just came across this. I had a similar problem in that the screw fell out so the little inner track fell out and the window wouldn't shut but I thought the problem with my window not shutting right was the seal that lines the track. I got a new (used) seal, pulled the old one out and discovered the problem was that the track had come out. Anyway, now I have to put the seal back in as well as the little track. It seems like I have to pull the window out to put in the track liner seal (right?). Does anyone have any idea what's the best way to pull the window or should I try and re-install the track seal with the window in place? The main issue seems to be getting the seal to line the track thats in the front of the car.
Thanks so much in advance. This forum is the best.
B
1994 850 wagon, 5 spd, 373,000mi
wheelsup
Postby wheelsup » Fri Mar 19, 2010 11:49 pm
Little confused on what you're talking about do you have any pictures?
1995 850 GLT Wagon w/ 185,000 miles
Wagonizer
Postby Wagonizer » Sat Mar 20, 2010 12:01 am
Thanks for the RE:. I'm basically tring to re-install all the felt that the pass window runs along...
hanzbe420
Year and Model: 1994 850 turbo wagon
Postby hanzbe420 » Fri Jan 13, 2012 2:31 pm
that same exact piece fell out of my door. i didn't no were it came from so i left it off. and i don't have any noticeable problems. Can you please tell me what this part is for lol. o its for when the door is closed it rattles around? yea mine does do that lol. well i guess thats another part to the never ending part list.
drtrance
Year and Model: 850 GLT 95
Postby drtrance » Tue Jun 05, 2012 4:55 am
"the never ending list" I'd say "the every time growing list"
So this happened to me today :( and sorry to ask if it seems ridiculous but... How did you removed all the panels to get to the window mechanism?
Thanks in advance.
Volvos are tough
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: alfatango1, ErikTh, luke lennard, MSNbot Media, sleddriver and 56 guests
