IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    '96 850 Rack & Pinion replace???
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby mtfrith » 06 Dec 2008, 18:13
    Have a '96 850 - Goodyear mechanic indicated that Rack & Pinion unit needs replacing. How do I know that he's right and not simply trying to replace something unnecessary. 2 years ago had it done...can't figure out why again. How do I self-diagnose & if so, any repair lessons on how repair myself. Thanks!
    1996 850 GLT Burgandy 160,000 mi
    mtfrith
    New Member
    New Member
    Re: '96 850 Rack & Pinion replace???
    Postby Matty Moo » 06 Dec 2008, 19:35
    Take it somewhere else. definitely.
    I wouldn't even take my bike to them.
    http://www.midwest-abs.com
    1996 850 Platinum Wagon. ARD Green Tune, OBX.
    1999 s70 Plain Jane.
    Matty Moo
    Senior Forum Member
    Senior Forum Member
    Model, Year: 850, 1996
    Postby MadeInJapan » 06 Dec 2008, 20:00
    Yes, get a second opinion. Due to economic and other reasons, a lot of these repair franchises are using unethical tactics. If you really do need a replacement, www.fcpgroton.com has good deals on refurbs that work fine.
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby larryh » 07 Dec 2008, 01:03
    I would assume he was checking the front end parts prior to an alignment and found looseness? Or is it leaking? You can look at it and see if it's leaking easy enough. Looseness is a little harder, but if the tie rod ends are good and the wheels can still be wiggled from side to side (3&9 o-clock), it's shot. I would have a good repair shop look at it. It was probably a remanufactured unit that was put in two years ago, so it's possible there is something wrong with it.
    larryh
    Forum Member
    Forum Member
    Postby Matty Moo » 07 Dec 2008, 05:43
    If it was a cheap reman unit, It could be shot. By cheap, I'm saying Autozone type of cheap, which is essentially garbage.
    It could very well be the tie rod ends, and the tech (inexperienced, inept) just says it's the rack and calls it a day. NEVER take anything to chain/corporate type joints. Most of the employees despise being there, which means they could care less about your car. They also don't fix your car starting with the problem, corporate policies dictate how they do their repairs. That means they start big, rather than just replace the one thing wrong.
    If Kansas is like Michigan, where everybody drives a domestic car, try damn hard to find a decent independent shop that works on foreign cars. You may have to drive, buy you'll save yourself a ton of headaches.
    Matty Moo
    Senior Forum Member
    Senior Forum Member
    Postby Ozark Lee » 08 Dec 2008, 02:49
    Unless the rack is bent from a collision chances are it is a leak. The last 850 I bought had a rack leak and - to my total amazement - Valvoline High Mileage Automatic Transmission Stop Leak fixed it. You can get it at Advance Auto Parts and likely other places like O'Reilly's. It is ATF with some seal conditioners so (warning to the turkey baster) you can just suck out the old stuff and replace it with the new. I did several iterations of that, ran the rack from lock to lock, and then sucked it out and replaced it again. It took about 1 full quart to "flush" the system.
    I have not yet leaked another drop.
    If you want an honest opinion try KC Autosport in Merriam. The are at more or less at I-35 and Shawnee Mission Parkway behind the pinheads at Aristocrat Motors, I think on Carter Drive.
    Stay very far away from Superior Volvo, they are thieves.
    If you do need to change the rack here is a link to a procedure for a right hand drive car - the left hand drive is a bit more complicated but it should help you out.
    http://volvospeed.com/Repair/power_steering.pdf
    Always here to help out a fellow JOCOer,
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Previous: 1989 740 GLT
    Postby mtfrith » 08 Dec 2008, 03:38
    Thanks to each of you for the helpful counsel. Lee, for the heads up on local support, I appreciate that direction. I have some extended time off coming up here in a week...and will be tackling this then. Kindly,
    mtfrith
    New Member
    New Member
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: Google Adsense [Bot], Mazur, MilehighV70XC, misha, Pauloil, rspi, wheelsup and 119 guests
