98 V70 Rear Washer Fluid not releasing
jbarrow8081
Postby jbarrow8081 » Mon Dec 29, 2008 5:45 pm
Hi - I have a 98 V70 with 145k miles. I am not getting washer fluid on the rear window. What i have checked so far....1) there is indeed fluid in the resevoir, the T Connection in the front is free and clear, I can hear the pump working. Is there another T connection that I should check or is it most likely the rear washer pressure valve? If so, is that an easy replace or worth a trip to the dealer? Thanks much!
billofdurham
Year and Model: 855, 1995
Re: 98 V70 Rear Washer Fluid not releasing
Postby billofdurham » Mon Dec 29, 2008 7:23 pm
There is an air valve vent under the left side floor panel in the load area. It looks a bit like a small petrol filter and they do occasionally block. Take the pipe off the forward end and see if water is coming out of the pipe. If yes re-connect it and take the pipe off the other end and try again. If yes suspect the jet on the tailgate.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jbarrow8081
Postby jbarrow8081 » Fri Jan 02, 2009 4:24 pm
Bill, Thanks so much for the info....when you say the left side floor panel in the load area do you mean the third seat section of the car? (my apologies, I am a bit of a novice). I appreciate your taking the time to reply. Happy New Year! Joe
billofdurham
Postby billofdurham » Fri Jan 02, 2009 7:25 pm
I don't know my left from my right :oops:.
In the luggage compartment, on the right hand side there is a wooden panel which pulls out and that is where the valve is.
Sorry, about the wrong location. How long did you work on this before you realised you couldn't find it?
My wife often tells me that if I could remember where I had put my memory I would be able to remember what I was doing before I lost it. I just say that it is old age.
Bill.
Previously:
jbarrow8081
Postby jbarrow8081 » Fri Jan 02, 2009 8:01 pm
Hi Bill,
Ha Ha, not to worry....i did figure out how to get to the floor panel released on the right side (no wasted time :)) but i didn't see the filter. Regardless, I traced the line upward and found a connection around the height of the right rear speaker. I pulled that connection apart and could get the washer fluid to come out of the connection. Based on that my guess is its a clog where the fluid actually comes out on the rear window. I will look for a pin or something small to try and see if i can get any dirt disloged that way. Any suggestions on the best way to do that?
On another front, I also had to replace the rear lift struts for the trunk. I found some information that you had posted a while back that was very helpful. The job took about 30 minutes for a novice like me. Now the trunk wont fall on my head anymore!!!
Thanks again for your helpful suggestions.
Joe
billofdurham
Postby billofdurham » Fri Jan 02, 2009 10:34 pm
For something like a washer jet I have acquired a very fine sewing needle from my wife's sewing box. It's a lot finer than a pin.
It also means that when she is looking for that needle I can come back at her with the memory thing. Revenge is sweet :twisted:
Bill.
Previously:
jbarrow8081
Postby jbarrow8081 » Fri Jan 02, 2009 10:51 pm
Thanks for the suggestion re: the sewing needle. Unfortunately all of the ones at my home are still in the original packaging. That explains all the holes in my socks. :( have a great evening!
Flag: United States of America
Postby MadeInJapan » Sat Jan 03, 2009 12:11 am
Unfortunately the "memory" thing doesn't work at my house yet...maybe next year when I hit 50? Anyway, the turkey baster...the needle- either of your tricks, Bill would send me to the couch for the evening. :mrgreen:
Oh, and the socks...hmmm. I'll have to ask her about that one.
I suppose the only thing I've succeeded at at my house is getting out of doing the laundry. Shrinking some white wool sweaters and turning them pink seems to have helped with that (couch for that night too, but it was worth it!). :lol:
outdoor7or24
Year and Model: SOLD 95 855t,93 945t
Postby outdoor7or24 » Sat Jan 03, 2009 2:18 am
jbarrow8081 - maybe this link will help. I have not tried this yet, but will this weekend to see if I can get my rear spraying again too.
viewtopic.php?f=1&t=9789&st=0&sk=t&sd=a&hilit=Windshield+Washer+Nozzle
Keep us posted on what worked for you, as you might help me locate my issue.
RSM-GA
Year and Model: C70 T5 Coupe 2002
Postby RSM-GA » Sat Jan 03, 2009 3:32 am
I, too, am having same/similar problem on my 2000 V70. I am NOT getting fluid to the rear valve, but my pump for the rear is working at the reservoir. So I am very curious to your resolution.
Please reply with your outcome so we can all benefit.
Thanks
Rob
[img]C:\Users\sony\Pictures\2010-01-17[/img]
My garage:
2002 Volvo C70 T5 Coupe
1998 Volvo S70 T5 91k sold
1999 Volvo S70 190k scraped
1999 Mercedes Benz E320 199k sold
2000 Volvo V70 SE sold
1999 Taurus SHO V8 sold
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Yahoo [Bot] and 36 guests
