RSS feed for Volvo Blog and Repair Database Follow MVS on Twitter!
due for PCV job
Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
1997 - 2000 C70
due for PCV job
Postby januwan » 08 Feb 2009, 18:15
I think I am due for PCV job, oily cap on the valve cover, some smoke from dip stick hole but no codes or any symptoms (may be mileage -23 in the city). I checked the flame trap (it was gone) it was clear but there was thin film of oil.
Is there anything else I could check before I remove the intake manifold.
Should I do this job immediately or I can still wait and learn more about the procedure. I red here, one can mess up injectors if not careful.
What are the consequences of postponing this job for few months
januwan
97 850 127k
januwan
Member
Member
Model, Year: 850 97 127K
Re: due for PCV job
Postby Ozark Lee » 08 Feb 2009, 18:41
Yanking the transmission to replace the rear main seal on the engine.
Other than that you just lose oil.
If it were me I would fix it sooner rather than later.
'94 850 N/A
'96 850 N/A
'98 S70 T5
Previous: 1989 740 GLT
Re: due for PCV job
Postby 850FLA » 08 Feb 2009, 20:07
I'm contemplating the same job [120K]. I have a small amount of oil at the cap and flame trap[I just cleaned it tonight] but only a small amount of vapor at the stick. Once it's warmed up virtually no vapor.
IMHO it's a job that is due at about 100k so I am doing it as a service item to avoid just what Lee mentioned...a rear main seal...big pita.
I recommend you do it ;)
850FLA
Member
Member
Re: due for PCV job
Postby januwan » 09 Feb 2009, 16:37
Thanks for the comments. I took it seriously :) and went to Volvo dealer to check their prices for replacement parts. Just the quote for few items on the list was more than $270 (FCP price for the complete kit is $155) and they quoted $480 for labor. Is it really 4 hours job for experienced mechanic.
januwan
97 850 127k
januwan
Member
Member
Re: due for PCV job
Postby MadeInJapan » 09 Feb 2009, 18:45
The 4 hours is what their book says so whether it takes them that long or not, that's what they'll charge you. A good mechanic who has done this many times can probably do 2 in that time period but will still charge you for 4 hours...that's the name of the business- more money in the dealer's pockets.
You might want to call Jamie or Don in the parts department at Darrell Waltrip Volvo (do a Google search for their 800 number) and see what they would charge for these parts- let them know that you heard about calling them from the forums for them to give you a decent price.
94 850 Sedan NA Drk Blue/Tan
Prev.- Blk on Blk '94 850 Turbo Wagon & '91 240 Sedan
Model, Year: '98 S70 T5
Re: due for PCV job
Postby Ozark Lee » 09 Feb 2009, 18:55
I think most of the stealerships work off of "book times". Doing the job the first time (of three) it took me about 5, maybe 6 hours. The last one I did I think I finished in 2 hours flat. I am a shade tree mechanic but I am not afraid to buy tools so I have a decent set of specialty tools. I also learned that I need additional hose clamps which saved the trip to the Auto Parts store mid job to get more parts on the later changes.
The learning curve is fairly steep on the first shot at it but once you have done the job once it is a relative snap.
It is much easier if you don't have EGR - The first one I serviced did have EGR and the others don't which helps with the quicker times.
If you want to take a crack at it yourself I think we can walk you through it.
'94 850 N/A
'96 850 N/A
'98 S70 T5
Re: due for PCV job
Postby januwan » 09 Feb 2009, 20:06
The reason I asked for labor quote was to figure out how much time it will take me to do it. I do not consider myself experienced mechanic and I usually multiply by 2 labor quoted by dealer. The most advanced job I have done was to replace head gasket on my small Honda Civic many years ago.
This job (PCV) has been described very well for Turbo, my is non-Turbo but I think they look similar under manifold.
I just do not want to damage injectors. I think it was you, Lee who did this job without removing fuel rail. I need to find it again.
januwan
97 850 127k
januwan
Member
Member
Re: due for PCV job
Postby confused_al » 09 Feb 2009, 20:42
...one can mess up injectors if not careful...
This is one guy from VS did PCV job w/o removing injectors, hope that helps;
http://volvospeed.com/vs_forum/index.ph ... pic=101431
95 850GLT
98 MB ML320
06 V70
confused_al
Senior Member
Senior Member
Re: due for PCV job
Postby Ozark Lee » 10 Feb 2009, 04:58
I have not removed the injectors on any of them. The only thing that is tricky is getting the fuel return line off since the hose is a little short. I loosen the upper clamp - it is easier to get to the upper clamp than than it is to get to the clamp on the fuel pressure regulator - and then just complete yanking the hose off as the intake manifold is coming off.
If you do wind up removing the rail I would have a full set of O-rings and the plastic injector caps on hand.
'94 850 N/A
'96 850 N/A
'98 S70 T5
Re: due for PCV job
Postby mingom » 10 Feb 2009, 07:50
On my 98 V70 N/A I didn't remove the injectors, just left it all on the manifold. Funny thing though, there was no fuel return line and no place for one... Just the one hardline on the end of the fuel rail.
'98 V70
mingom
New Member
New Member
Re: due for PCV job
Postby januwan » 11 Feb 2009, 13:28
Just ordered the kit from FCP (mentioned recommendation from this forum). If it will arrive on Friday I will have Saturday covered.
Everybody, on Saturday, do not go anywhere and check the forum frequently... I will be asking questions :)
Confused_al thanks for pointing me to the thread.
januwan
97 850 127k
januwan
Member
Member
Re: due for PCV job
Postby Craigd2599 » 11 Feb 2009, 15:40
Have you guys tried this site? http://www.pelicanparts.com/catalog/sho ... htm#item12
$30 for the Oil Trap...volvo genuine parts.
Craig D
Philly boy stuck in Nashville
1995 850 GLT Emerald Green 155K
Lusting after an S80 Turbo
Craigd2599
Senior Member
Senior Member
Model, Year: 850 GLT N/A 1995
Re: due for PCV job
Postby Ozark Lee » 11 Feb 2009, 16:46
Pelicanparts is my preferred vendor for Porsche parts (I've spent thousand there on my daughter's 944) but on Volvo the inventory is slim, the shipping is high, and I've found them to be more expensive than FCP and eEuro.
Great people though.
'94 850 N/A
'96 850 N/A
'98 S70 T5
Re: due for PCV job
Postby confused_al » 11 Feb 2009, 18:44
...Confused_al thanks for pointing me to the thread....
You are welcome!
Just dont let MIJ and Lee convert you to a volvoaholic like they did to me....LOL :lol: :lol:
95 850GLT
98 MB ML320
06 V70
confused_al
Senior Member
Senior Member
Next
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: BillyI, bobice, bronxnativ, ecbsykes, farmer66, Frostydog, JDS60R, MSN [Bot], pkc303, thecheat, Yahoo [Bot] and 53 guests
Click to go to Denver's Premiere Volvo Shop
Click to go to Discountvolvoparts.com
