Please don't use image hosting services like Image Shack. Here's why.
Having trouble logging in? Please delete http://www.matthewsvolvosite.com cookies in your browser. Here's how.
XC70 00MY P0014 Cam Position Code
ldiii@hotmail.com
Postby ldiii@hotmail.com » Mon Mar 09, 2009 9:07 pm
I’ve got a P0014 “Cam Position Activator B, Bank 1, Timing Over Advance" code that I can’t get rid of. I’ve replaced the Cam Actuator Solenoid so that shouldn’t be the issue and I’m sure the timing is perfect. I’m thinking that it might be the Cam Position Sensor, but before I go that route I wanted to post here to see if anyone could tell me how to test. I don’t want to buy a new one if I don’t have to!
If anyone has any info on this I'd greatly appreciate it.
LD
XC70 00MY
112k
Recently replaced the following:
- fuel pump
- ignition coils
- plugs
- ETM
- oil trap
Year and Model: Many Volvos
Flag: United States of America
Re: XC70 00MY P0014 Cam Position Code
Postby Ozark Lee » Mon Mar 09, 2009 9:52 pm
That code points to a problem with the continuously variable valve timing control solenoid. None of my cars have CVVT so I have no hands on experience with it. Hopefully others that have worked with it will jump in.
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
Year and Model: '98 S70 T5
Postby MadeInJapan » Mon Mar 09, 2009 9:54 pm
I did a bit of research on this over on VolvoSpeed:
http://www.google.com/search?sourceid=M ... com+=P0014
And my conclusion is that even though your car might be running fine, it could be a tooth off or it could actually have an oil pressure problem to the solenoid itself. What you describe is hardly ever the Cam Position Sensor itself.
larryh
Postby larryh » Mon Mar 09, 2009 11:31 pm
So, did it perhaps start setting the code shortly after a timing belt change?
It's not uncommon for the timing to be off. Trust me :wink:
If you are positive the timing is correct , then I have a VVT solenoid, that there is nothing wrong with, that I would give you a fantastic deal on.
ldiii@hotmail.com
Postby ldiii@hotmail.com » Tue Mar 10, 2009 1:22 pm
thanks for the quick replies guys. is the VVT solenoid the same as the cam actuator solenoid (this has already been replaced)?
It sounds tho like it is not the cam position sensor.
ldiii@hotmail.com
Postby ldiii@hotmail.com » Tue Mar 10, 2009 1:23 pm
in response to your question larryh, I don't know. I got the car just after the timing belt was changed, so don't know if that code was being thrown before or not.
Postby Ozark Lee » Tue Mar 10, 2009 2:55 pm
It is the same thing. Your code indicates that the timing is overadvanced, not that it isn't working.
'98 S70 T5
'96 850 N/A
VCA
Postby VCA » Tue Mar 10, 2009 3:01 pm
Correct, the timing belt and condition of the timing gears needs to be checked, probably very soon, given that the t-belt was due at 105K. If the belt has stretched it could break soon and that would be fatal to the engine.
2008 S80 T6 AWD
1999 S70 GLT
db130
Postby db130 » Wed Mar 11, 2009 1:21 pm
I've been in your shoes.
Bought my car at 114k, the car had just recently had the timing belt done at 105k. I replaced the VVT solenoid due to the P0014 code, it kept coming back. I then followed this fellow's advice and changed the camshaft position sensor:
http://forums.swedespeed.com/zerothread?id=45940
Since the VVT relies on oil pressure, oil quality and oil pressure are crucial. now that i am keeping a close eye on the oil level, i have not had the code in 9 weeks and counting.
2002 V70 T5 155k
2002 V70 NA 235k
2006 Mini Cooper S 85k
ldiii@hotmail.com
Postby ldiii@hotmail.com » Thu Mar 12, 2009 5:43 pm
thanks for the post db130. so you did end up changing the cam sensor? what did it run you if you don't mind me asking? I think I'm going to check the timing one more time to make sure that isn't the prob before pulling the trigger on the sensor.
my fuel economy is suffering due to this as well I believe. I'm only getting 20 mpg on the highway when I believe I should be getting much higher.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Clemens, MSNbot Media, opelrick, RigsPGT and 33 guests
