IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    Climate unit blower replacement
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Re: Climate unit blower replacement
    Postby Sperry » 06 Apr 2009, 23:41
    Thanks for the resistor photo, Lee. It makes more sense when the dash is opened up.
    I got the blower out. Boy, what a mess the windings and blower cage have become.
    Now I know why people like to use new components. Salvaged parts might have the same problem.
    Still, I'm going to install a pulled part. If the blower resistor is faulty,
    I'll fix it [one might be included with the blower].
    This link to a schematic also shows the resister location.
    1994 850 Turbo Sedan. 202,000, and getting more experienced, not older. - sold
    Sperry
    Forum Member
    Forum Member
    Model, Year: 850 Turbo 1994
    Postby Sperry » 11 Apr 2009, 20:23
    The upshot on my blown blower fuse is that I swapped out the 30A fuse with the power antenna fuse, and have been enjoying audio books on CD without the antenna raising and lowering. I'm thinking about a dash-mount toggle [factory, of course] for the antenna.
    Cleaning the blade connectors and a lube brought my blower back for a few days, but it is back to intermittent. Fortunately, the salvaged is here [$37, and looks good].
    I couldn't find the blower resister on myswedishparts.com
    Can anyone shed light on this?
    Sperry
    Forum Member
    Forum Member
    Postby Ozark Lee » 12 Apr 2009, 01:03
    The part number I come up with is 9144354 for the power stage (ECC blower resistor) but they normally aren't intermittent. They either don't work at all or the blower runs constantly when the power stage fails.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Previous: 1989 740 GLT
    Postby charliefoxtrot » 07 May 2009, 01:18
    Again, very nice write up!
    I removed the blower motor to remove debris that got into the plenum. After cleaning out the stuff, I reinstalled the unit and reconnected the electrical. The fan immediately began running at high speed. The ignition was switched off and the fan control was off.
    Do I need to reset a relay or did I screw something up?
    charliefoxtrot
    Model, Year: '97 850
    Postby Ozark Lee » 08 May 2009, 11:55
    When they run constantly it normally means that the power stage (blower resistor) has shorted out. For some reason the power to the blower is not switched with the key.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Postby Sperry » 08 May 2009, 12:28
    My experience was odd.
    Blower fuse failed, replaced fuse.
    Fine for days, then intermittent function.
    Replaced blower w/ salvage unit.
    Fine for days, then intermittent function. Code 411, 418 [I think it was].
    Replace power stage with new unit.
    Fine for days, then intermittent function. One last failure.
    Pulled ECC, unplugged and plugged in wires.
    Everything fine since. Knock wood, but it's been weeks.
    I can ship you my old power stage for a nominal fee; however, although it never fully failed as described by Lee, the resisters show evidence of "leaking and oozing", and intermittent function is strongly suspected.
    Even though my car has 160K miles on it, if I was doing it again, I'd buy a new blower and new power stage from Darrell Waltrip. Just like I should have bought a new radiator fan last year, but put in a salvaged part, ad did the same last week [after enduring driving with the windows down and the heater on, and scrambling for a replacement fan].
    If JRL's upcoming '97 850 T5 had appeared three weeks ago, I might have jumped.
    However, at this point, I'm committed for another year or three.
    Sperry
    Forum Member
    Forum Member
    Postby tailor » 23 May 2009, 23:19
    It is easy to remove the fan from the motor assembly. Mark the top of the fan and motor shaft with paint (it is a balanced assembly). Place the bottom of the fan on a couple blocks of wood on each side. With a drift, lightly tap the shaft through the fan assy.
    If this is true and I believe it to be so, how then can an existing cage be attached to a new motor and the balance maintained or be determined?
    1994 850 Auto Turbo wagon 306000km (Sold)
    2004 XC90 AWD 188000km
    "Life is like a reel to reel tape recorder,
    the closer you get to the end,
    the faster it spins."
    Abe Gottschalk
    tailor
    Forum Member
    Forum Member
    Model, Year: 1994 850 Turbo Wagon
    Postby MadeInJapan » 24 May 2009, 00:02
    As long as the blades aren't messed up or bent, the way the motor fits in the cage will automatically assure balancing. I've not changed the cage myself but have friends who have and it works fine- I just thought the trade off of savings just wasn't worth the hassle.
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby tailor » 24 May 2009, 06:23
    Thanks for the input MIJ
    I was giving the balancing issue a little more thought, and came to the conclusion that it must be a similar type of thing to wheel balancing. Most wheel balancing is done with the wheel off the car.I guess a similar approach is for the cage. So the orientation of cage to shaft is of no consequence.
    Abe Gottschalk
    tailor
    Forum Member
    Forum Member
    Postby Sperry » 24 May 2009, 10:44
    The cage uses a clip to add weight at a particular side.
    Sperry
    Forum Member
    Forum Member
    Postby arsenal6 » 04 Jun 2009, 05:35
    Sorry can you show a picture of the rear and front bearings and what should I lubericate with? Just WD-40?
    arsenal6
    New Member
    New Member
    Model, Year: volvo 850
    Postby Ozark Lee » 05 Jun 2009, 04:47
    I may have some pictures but it will be tomorrow before I can retrieve them and post them up. I am in the middle of the second recovery attempt on my network drives and it is in the middle of a write cycle at the moment to the backup drive where the pictures now live. Once the cover comes off the rear bearing is very obvious, the front one is tough to see unless you remove the blower cage blower. I just soaked it with WD-40 but I'm sure there is a better lubricant. WD-40 was just the aerosol oil that I had on the shelf at the time.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Postby stylebox » 11 Jul 2009, 06:31
    Lee,
    I followed the instruction at the beginning of the forum and this topic. Did it in one hour, used an aftermarket part from CleanAirParts for $85.00. Everything is cool. Literally. Thank you for your great posting!
    :D
    stylebox
    Model, Year: 850R '96
    Postby Ozark Lee » 11 Jul 2009, 07:39
    Welcome to MVS,
    I'm glad it was helpful. Did you get the entire assembly for that price?
    I tried to Google them but there is so much noise on the clean air act that I couldn't find a link.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    PreviousNext
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: Ben850, deepsouth, fbfmcote, jlindse1, mochaed, Pauloil, piesia and 93 guests
