IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    Climate unit blower replacement
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Re: Climate unit blower replacement
    Postby Rich_Lovina_99 » 09 Sep 2009, 15:58
    My blower only seems to be working on low speed; the high manual air blasts have all but disappeared. What might be the cause? Tks in advance.
    Rich_Lovina_99
    New Member
    New Member
    Model, Year: 850T 1995
    Postby Ozark Lee » 09 Sep 2009, 22:01
    Welcome to MVS,
    Before we can start to figure it out we need to know what style of climate unit you have. The manual climate control (MCC) has fan speeds that range from 0 to 4 and the temperature settings are marked by graduated width red bars. The electronic climate control (ECC) has an Auto setting on the blower speed and the temperature settings are in degrees.
    Let us know what type of unit you have and we can work from there.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Previous: 1989 740 GLT
    Postby Rich_Lovina_99 » 10 Sep 2009, 03:10
    Hi, thanks, I worded that badly. Its a '95 850 Turbo with automatic climate control. What I meant was, until recently, if I turned it manually to max air (e.g. demisting), it would blow with full power. That function of the blower is not now working. e.g. with cold weather at present, if I set at 25 c. fan only blows gently to warm the car.
    Rich_Lovina_99
    New Member
    New Member
    Postby marginal » 28 Oct 2009, 04:13
    Hello everyone and thank you for the helpful topic :) ...
    I have the electronic control unit on my car and with the cold weather I noticed it almost does not blow hot air through the lower vents:
    I turned the power to maximum and it started making noise, but not enough air flow.
    I thought the electronic control in the middle does not work, but when I turn it, it changes something as the noise changes.
    Also, when I turn it completely down ( @ six o'clock for the floor air flow) it blows from the top too :shock: ...
    So, probably my air ducts are dirty or my blower motor is exhausted?
    Please help.
    www.keysrus.info
    marginal
    Forum Member
    Forum Member
    Model, Year: 850 GLT 1997
    Postby Rich_Lovina_99 » 28 Oct 2009, 08:27
    Now that hot weather is here suddenly, like 38c, my fan seems stuck on lowest speed only...still working and cooling car, but very gradually. Or does a fan effect come just with air-con on? Makes no difference 'auto' or 'full manual power'.
    I guess if there's no boost its the fan has given up??
    Rich_Lovina_99
    New Member
    New Member
    Postby Ozark Lee » 29 Oct 2009, 02:35
    Marginal,
    You problem is likely with the mode damper - on an ECC that is easy to get to through the glove box. Remove the damper motor and inspect the shaft, it is common for the end of the shaft to split.
    Replacing the damper flap is a huge job, the entire dash needs to come out to do it but it can usually be repaired in place by either sliding a bushing over the end of the shaft or wrapping the shaft with a fine - 22 gauge to 24 gauge - solid copper wire. In the end it is much like the joints on a fishing rod are reinforced.
    EDIT: I just found your repair post - well done.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Postby marginal » 29 Oct 2009, 04:11
    Thank you Ozark Lee ...
    I repaired it today.
    Great forum and great people here :) ...
    www.keysrus.info
    marginal
    Forum Member
    Forum Member
    Postby Pauloil » 12 Nov 2009, 04:50
    I replaced with new blower motor that has been in my garage for a few yrs.
    incredible difference on my 95 850! It is not that hard to drive the cage off of shaft, but next time I will just but the whole assembly.
    Thanks to Ozark Lee for useful writeup and pics!
    99 V70XC 158K
    95 850glt 188K
    Pauloil
    Forum Member
    Forum Member
    Postby marginal » 12 Nov 2009, 04:54
    Hello everyone.
    Does anyone have an idea how to disassemble and lubricate the fan's shaft so it starts turning freely?
    Thanks.
    www.keysrus.info
    marginal
    Forum Member
    Forum Member
    Postby BEJinFbk » 12 Nov 2009, 05:55
    marginal wrote:Hello everyone.
    Thanks.
    You can take it apart more than once and try to fix something
    that sounds like it's well beyond it's "sell by" date,
    or just buy a new one and only do the job once.
    I mean, C'mon...You live in Montreal and winter's comin'...
    You do NOT wanna mess with this when it's cold out. Never fun.
    Call these guys and at least get a price:
    DW Volvo / Parts Dept
    (800) 689-0021
    Ask for Don or Jamie
    Stay Warm! :mrgreen:
    BEJinFbk
    Senior Forum Member
    Senior Forum Member
    Model, Year: '98 V70 R
    Postby marginal » 12 Nov 2009, 06:02
    Hi BEJinFbk and thanks for you reply :) ...
    I forgot to explain: Everything seems to be working OK with my blower.
    I am asking about lubricating because I bought a spare second hand blower and when I turn the fan, it does not turn very easily.
    I guess this is more clear now :mrgreen: ...
    www.keysrus.info
    marginal
    Forum Member
    Forum Member
    Postby bobice » 17 Nov 2009, 04:24
    My Volvo problem is that the fan runs at max speed as soon as the car is started. After reading this post and others, it seems that the power stage (ECC) has failed and I need to replace it. Can I just get it from Pepboys or AdvancedAutoParts?
    bobice
    Forum Member
    Forum Member
    Model, Year: XC70 1999
    Postby suzinthecity » 17 Nov 2009, 04:43
    How much would it cost to have a mechanic repair this? I suspect that is why my 850 GLT doesn't give me any defrost, AC or heat anymore. It starts for a split second when I start the car, then dies and I can't use any knobs to control it. I have little to no technical ability, so I am wondering if this is something a repair place would do at a reasonable price?
    Thanks
    suzinthecity
    Model, Year: 850 GLT, 1995
    Postby djohnk » 09 Dec 2009, 04:53
    I have a 1998 V70XC I am trying to get ready for a trip up north for Christmas. I just replaced my blower unit (using the excellent instructions in this post, and this video: http://www.howcast.com/videos/51461-All-How-To-Replace-Blower-Motor-in-Volvo-S70-V70-C70-XC70). I also removed and cleaned the temperature sensor. My AC and Heat worked fine for most of the day, but tonight the old problems came back. When I start the car two yellow lights on the electronic climate control blink for about 20 seconds, and I get no air from the blower. I suspect 9 months of using a bad blower messed up the power resistors, but I don't know how to diagnose. Can anyone give me trouble shooting advice? I don't want to purchase a new one at $100+, and find out that wasn't the problem.
    I have one other question, I removed the radio easily using the instructions here: http://www.howcast.com/videos/51463-All-How-To-Remove-Climate-Control-in-Volvo-S70-V70-C70-9800 but can't seem to remove the electronic climate control module. The video makes it look easy, and I can't budge it, trust me I'm a big guy and should be able to remove it. I don't want to break it, but am not sure if something changed in the design. Anyone else have this problem?
    djohnk
    New Member
    New Member
    Model, Year: V70XC 1998
    PreviousNext
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: btwagner, Google [Bot], Jellobmw, nzaac, olpossum, senior and 79 guests
