Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
by Gregg » 21 Mar 2009, 00:57
Hello I have a 1993 volvo 850 glt that has a haunting intermittent stalling problem it only occurs when the car is at operating temp and when the ambient temp is at least 70 degrees I have replaced the fuel pump and relay Crankshaft sensor and Camshaft sensor the only code it gives is ignition system rpm erratic #214 if anyone has any ideas please let me know
thanks Gregg
Gregg
- Model, Year: 850 1993
by MadeInJapan » 21 Mar 2009, 07:15
Welcome to MVS.
I hope you get an answer to your question.
You have looked at the things I would have looked at.
I'm thinking that at this point it could be faulty wiring from the RPM sensor (camshaft sensor)...look at all of your wires from the battery and that unit and see if you can back probe any electrical shorting or chafed wiring...
94 850 Sedan NA Drk Blue/Tan
'00 V40 Purple/Grey Mobil-1
- Model, Year: '98 S70 T5
by Ozark Lee » 21 Mar 2009, 13:04
Check the proximity of the leads from the RPM (Crank) sensor to the ignition wires. There was a TSB that called for using a ty-wrap to secure the wires away from the high tension ignition wires. In its natural state the leads want to loop up near the coil wire.
'94 850 N/A
'96 850 N/A
'98 S70 T5
'99 V70XC
Previous: 1989 740 GLT
by nswanson » 31 Jul 2011, 21:32
Gregg,
Your post is a few years old but I don't see a resolution. I am having the same problem with my 1193 volvo 850 glt. Did you solve this problem?
thanks,
Nancy
nswanson
- Model, Year: 1993 volvo 850 glt
by Gregg » 31 Jul 2011, 22:32
sorry nancy i never found the problem on that car so if you find it please let me know
Gregg
by JimBee » 01 Aug 2011, 01:19
I think I have read on this site that the temperature sensor can cause interferences with critical systems. Maybe someone else will add more to that.
JimBee
- Forum Member
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: Bing [Bot], buzz4matt, erikv11, Google [Bot], j-dawg, Jellobmw, MrPc, Pauloil, piesia, taupehat, TRuck, V70Newbie and 129 guests
