lifter tick
phils94850
Year and Model: 96 850 Platinum
Flag: United States of America
lifter tick
Postby phils94850 » Sun Jan 10, 2010 8:57 am
I've noticed after starting and engine cold and after a couple minutes I'm getting a noticeable lifters ticking. It doesn't do it on initial start when cold, they start after a couple minutes.
After I drive for about 10 or 15 min. Then its quiet and doesn't come back. I jus changed the oil yesterday and used 5w30 and it seems like it made the ticking worse.
Any ideas on what I can do to help with the ticking and is it hurting anything? I've read the ticking can last up to 15min. And its normal. The engine has 176k miles.
1996 Platinum Edition
meteg
Year and Model: 2007 V70 2.0T
Re: lifter tick
Postby meteg » Sun Jan 10, 2010 9:41 am
hello,
for an engine that has 176,000 miles it will be wiser to use semi synthetic 10w-40 oil. this is recommended by the oil manufacturers too.. the full synthetic will be too thin for a moderately worn engine and the worn valve terrain.. especially for the engines which have hydraulic lifters like our volvos have the valves get oil starved because the full synthetic doesnt fill the worn parts with oil.. the oil has to be thicker so it will fill the worn parts..
but the engine valves will tick if the the car is not used for more than 10 days.. and that is normal.but it shouldnt tick after it reaches operating temperature..
phils94850
Re: lifter tick
Postby phils94850 » Sun Jan 10, 2010 10:26 am
When I changed the oil yesterday I used regular non synthetic 5w30 oil. I figured a full synthetic wouldn't be good on a older engine. With temps getting down in the single digits where I live what's the heaviest weight oil I can use ? I've also read about people using lucas oil treatment ?
I'm getting the ticking after the car sits for example all night.
meteg
Re: lifter tick
Postby meteg » Sun Jan 10, 2010 10:46 am
the best thing to do is to switch to semi sythetic oil like 10w-40.this will cure your problem.. when you use oil additives it will ruin the engine oils chemical structure.. the oils which are used in the market already have some additives in them.. and using another additive is not recommended by the manufacturers..
other members of the forum will soon see the post and make more comments..
by the way I forgot to mention, make sure the oil level in your engine is at the maximum mark if it is not bring it to the max line..
phils94850
Re: lifter tick
Postby phils94850 » Sun Jan 10, 2010 11:18 am
Meteg.. Thanks for the advice ill give it a try
JRL
Year and Model: Several
Re: lifter tick
Postby JRL » Sun Jan 10, 2010 1:57 pm
Try giving your engine a SEAFOAM treatment
Costs you all of 10 bucks.
Also could be your O-rings in the oil pan (common issues with high mile Volvos)
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
jblackburn
Year and Model: 1998 S70 T5
Re: lifter tick
Postby jblackburn » Sun Jan 10, 2010 4:12 pm
+1 on the Seafoam treatment. You'll have to change your oil after anyway.
The oil pickup rings in the oil pan deteriorate with age, and cause the oil pump to pick up less oil at idle, and cause the tick you describe. I'd try other things before tearing into that though.
If you're not leaking oil visibly anywhere, making the switch to synthetic is one of the best things you can do for it. I switched to Mobil-1 10W-30 from dino oil 30,000 miles ago with no problems, and my car has never been happier.
'98 S70 T5
2012 Chevy Cruze LT 6MT
Year and Model: Many Volvos
Re: lifter tick
Postby Ozark Lee » Sun Jan 10, 2010 10:45 pm
What brand of oil filter did you use?
Anything other than OEM Volvo, Mahle, or Mann will cause severe lifter noise on startup. I have heard that K&N and the premium NAPA filters are OK but I have never used them and thus I cannot vouch for them. Fram filters are the orange cans of death - I did try a Fram filter - once.
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
renns
Year and Model: Volvo V70 1998
Re: lifter tick
Postby renns » Mon Jan 11, 2010 2:06 am
-1 on SeaFoam - sorry guys, but I feel compelled to provide this link. The noise, which appeared after SeaFoam treatment, continues to this day, and was confirmed by an experienced Volvo mechanic to be stuck lifter(s). It's been about 4k miles since the SF treatment. I've tried various oil types and weights, and also changed out the oil sump o-rings. Nothing's left but swapping out the lifters, and I just couldn't be bothered on an old high-mileage car. It runs great, and the mechanic said the ticking wasn't of a nature that required immediate replacement. He indicated the car would likely run for years in that condition.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 144,000 km - daily driver
850 Turbo1
Year and Model: 1996 Volvo 850
Re: lifter tick
Postby 850 Turbo1 » Mon Jan 11, 2010 4:15 am
renns wrote:-1 on SeaFoam - sorry guys, but I feel compelled to provide this link. The noise, which appeared after SeaFoam treatment, continues to this day, and was confirmed by an experienced Volvo mechanic to be stuck lifter(s). It's been about 4k miles since the SF treatment. I've tried various oil types and weights, and also changed out the oil sump o-rings. Nothing's left but swapping out the lifters, and I just couldn't be bothered on an old high-mileage car. It runs great, and the mechanic said the ticking wasn't of a nature that required immediate replacement. He indicated the car would likely run for years in that condition.
-1 on sea-foam as-well ...there are many people who have had the seafoam method do more damage than repair and clean...lots of stuff on the forums if you search..GODLUCK!
1996 850 T5 Sedan
1996 850 T5 Platinum Edition Wagon
--Always Learning--MB--
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: 98v70dad, ACarmona, BEJinFbk, Bing [Bot], jantt, Matty Moo, Mcass777, misha, MSNbot Media, Pezgoon and 46 guests
