If you're having trouble logging in, please delete cookies for this site.
Procedures to replace Viscous Coupling
bobice
Forum Member
Forum Member
Year and Model: XC70 1999
Postby bobice » Sun Jan 31, 2010 2:58 am
My 2000 V70XC AWD makes some noise due to a bad viscous coupling bearing. Since I might be able to get a used VC from another salvaged V70, I am researching on how to do the work. The attached two files are the instructions from VADIS. According to the instructions, I need some special tools, such as the counterhold (9995743) and the dial gauge (9995971). Are these tools absolutely necessary? If so, where can I get these tools?
Any shortcut or tips on how to replace the VC would be appreciated. The AWD is so nice for the Maryland snow!
Thanks.
Replacing viscous coupling.pdf
(1.39 MiB) Downloaded 797 times
Measuring and balancing viscous coupling.pdf
(310.87 KiB) Downloaded 428 times
capecodbuilder
Forum Member
Forum Member
Year and Model: 1997 850 glt, 2000 v
Re: Procedures to replace Viscous Coupling
Postby capecodbuilder » Mon May 03, 2010 11:12 pm
I am also looking for someone with some experience swapping out viscous couplers. After reading the instructions in vidas I was not going to try, instead drive it as a fwd. I now have 5 awd volvos in my possession. All have something wrong with the awd some bad angle gears some bad viscous cplrs. all great cars.
At least one is to be a donor car and at least one of the others is going to end up a fwd.
Adding to my hell is the fact that there are differences with these parts even within the same model year.
I have 3 v70 xc's a 2000, a 99 and 2 98's. I also have a 99 s70 awd.
I see that nobody answered this post and I'm calling you big dogs out!! :D
I plan on swapping a viscous cplr out and throwing a driveshaft from a 3rd car and just bolting it up. the instuctions have you keeping the bolts in the same holes, using flipping dail gauges and such...too much like brain surgery.
Anyone done this? good results?? bad??
Also how about a lesson on using vadis to find out the different parts and there interchangeability? I ask for the world here I know, but I also know that I am asking the right group of people.
Thanks in advance you crazy volvo-heads!
JRL
Longtime Member
Longtime Member
Year and Model: Several
Flag: United States of America
Postby JRL » Tue May 04, 2010 3:28 am
Remove propshaft
Unbolt old VC
Remove old one
Replace with new one
Install propshaft
Very simple
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
capecodbuilder
Forum Member
Forum Member
Postby capecodbuilder » Tue May 04, 2010 7:14 pm
WOW! now that was a really thoughtful response... yeah, I get how to do it if your a freaking primate. I have no problem in that area. I am an ape.
Heres the rub... I read the instructions for how to do it if your a Volvo dealership making a fortune reinventing the wheel, while being payed by the hour,and it left me (and the original poster) feeling that, perhaps, the knuckle-draggers method (that jrl describes in such poetic detail) will leave me with a vibrating and self-destructive V/C... hardly worth the effort when driving it as a fwd is fine.
So I'll re-word the question... has anyone simply bolted up a V/C from a donor car without following the ridiculously drawn-out process described in the attached vadis pdf? If you have done so, please share your results.
steve_v70xc
Year and Model: V70XC, 1999
Postby steve_v70xc » Mon May 10, 2010 4:24 pm
Hello capecodbuilder,
I have a '99 V70XC with most likely a bad viscous coupler -- I'm hearing some noise in that area and it's getting louder. My mechanic took a look and said it could be that I need to replace the viscous coupler entirely or just replace the viscous coupler bearing -- the VC was not removed from the car, it was inspected in place on the car. A third potential source of the noise, according to my mechanic, is the rear differential. The inspection has already cost me $115 and to pull the VC off for further inspection will be another $300. Then, if the VC is bad I've heard it will cost around $1300 for the part. After spending $4K on this car in the past year or so (and only driving it 10K miles in that time!) I'm getting pretty tired of the expenses. Which brings me to my question (sorry it took so long!) -- what do you mean by "drive it as a FWD?" Can I just let this go (no repair)? This is way beyond my mechanical abilities/knowledge -- I'd like to keep the car if I can drive it WITHOUT making any repair to the VC -- I don't care if the AWD in non-functional, FWD is fine with me. I just don't want the car to leave me stranded or cause an accident. If this is not an option, I am going to sell this car and move on, the maintenance/repair costs are killing me since I can't do much of the work myself.
Thanks in advance for any and all replies/suggestions!
Steve
P.S. The car has only 116K miles on it! Such a short life considering how many problems I've had with it.
bobice
Forum Member
Forum Member
Postby bobice » Mon May 10, 2010 4:59 pm
Based on other threads, I think it is OK to leave the car as is, if you don't mind the noise. That's what I'm doing now.
I plan to take the VC out once the noise is un-bearable. But it's absolutely OK or may be better to remove the VC now and make the car FWD.
steve_v70xc wrote:Hello capecodbuilder,
Steve
capecodbuilder
Forum Member
Forum Member
Postby capecodbuilder » Mon May 10, 2010 5:02 pm
Hello Steve, Yes you can convert to fwd. All that is ness. is that you take out your drive shaft...and call it macaroni.
I have done this and I'm happy. There are a few threads on this site pertaining to this method of dealing with the troubled awd set-up on these Volvo's. If your rear-end is faulty you might be a good candidate for the next step, a step I'm about to take. I'm not too sure about anyone else talking about this aspect on here but here goes...(also, anyone with an opinion or experience in doing the following please chime-in)
Once you disconnect the drive shaft, you are driving a fwd wagon. The only thing I am not thrilled about is the fact that I am still turning an angle gear and dragging a rear diff around which is a waste of gas/power.
This is esp. a prob if the angle gear or rear diff is faulty/noisy.
As far as I can tell the angle gear is holding a sleeve onto a shaft that comes out of the tranny and perhaps adhering the sleeve to the shaft is all that is ness to remove the a.g. all together...and sell it for a few hundred bux!
As for the rear diff. I am going to remove the axle's from the rear and drain any fluid out of the diff...allowing the rear tires to spin freely and not turn a useless (and in your case noisy)rear diff.
JDS60R
Year and Model: 2007 S60R 2004 XC70
Postby JDS60R » Mon May 10, 2010 7:21 pm
You can remove the rear shafts and then you only have the dead weight of the coupler and differential. This elimates the internal drag.
I'm not sure the diference in gas mileage is worth the effort but if my diff or AOD was going the you could consider it.
Streetlight Insurance Brokers See what the market has to offer you !!!
Car, Home, Boat & Motorcycle Insurance in Tennessee
"Now its your turn to start saving"
Free VIDA Volvo code readings at my Mount Juliet, TN location
steve_v70xc
Postby steve_v70xc » Tue May 11, 2010 7:07 pm
Thank you all for your helpful replies. I will search this site for the procedure to remove (and not replace!) my driveshaft (same thing as propeller shaft, I assume). As long as the noise is gone and the car is safe I'll be happy. Kind of sad that I haven't had many chances to take advantage of the AWD. It's only been in the show a few times, but when it was, it really handled well. And it's always felt so stable on wet/slick roads. I've assumed that was due to the AWD but maybe it's just the car in general. So solid compared to other cars I've recently owned (Accord, Camry, Sienna).
JRL
Longtime Member
Longtime Member
Postby JRL » Tue May 11, 2010 9:03 pm
You can also remove the VC with the driveshaft.
Since there won't be anything going to the rear diff, it probably will be OK afterwards and to the OP, it really IS that simple;
just unbolt the VC and remove it
(Put the bolts back in (just in case) so the bolt holes won't rust up
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: No registered users and 29 guests
