Automatic Climate Control Problems? Try This!!
phat78ta
Year and Model: 94 850 turbo wagon
Postby phat78ta » Thu Feb 18, 2010 11:47 pm
I will begin by saying that Volvo makes an awesome car.
I recently started having issues with my ECC unit. The dreaded flashing lights. So I pulled codes, and found lots of issues, the temp fan, the blower motor, damper motor and others. I thought that the ECC control unit had given up the ghost. After looking into it, I found the temp sensor was working correctly, and the blower motor was woking properly also. Upon looking into the damper motor, I found that it was not working.
So, like any good do it yourselfer, I took the damper motor apart. I figured if it's broken, I can't break it anymore. Upon opening the housing, I found the circuit board covered in white grease. I cleaned some of it off before this pic:
The black half circles were covered in grease also. I cleaned it off, and plugged it back in. all the codes went away, and the motor operated normally.
These contacts touch the black half circles:
The grease is from the gears in the reduction system, and must have gotten on the contacts over the years.
Put everything back together, and all is well.
So, If you get the dreaded flashing lights, this is one more place to check before replacing parts.
93 850 GLT sedan 156K
94 850 Turbo 189K
matthew1
Site Admin
Year and Model: 850 T5, 1997
Flag: United States of America
Re: Automatic Climate Control Problems? Try This!!
Postby matthew1 » Fri Feb 19, 2010 2:00 am
Good work! Entered into the Repair Database.
Please buy from MVS sponsors. It keeps this site on the web.
Like this spam-free, organized forum? Thank a moderator.
Thanks for choosing MVS!
How to help MVS.
1997 850 T5, MBC, injectors, R bumper, strut brace, dying paint
FCPEURO
Year and Model: 2009 S60 2.5T
Postby FCPEURO » Fri Feb 19, 2010 2:33 am
Awesome find. I never thought to pull one of the motors apart to see if they could be fixed. I just assumed that when they go, they go.
Jason VanGorden
Volvo Product Manager
JasonV@FCPEURO.COM
FCP Euro - European Car Parts Specialists
Quality & Service, Guaranteed for Life
155 Hill Street, Milford, CT 06460
phat78ta
Postby phat78ta » Fri Feb 19, 2010 10:14 pm
I thought the same thing too, so that's why I tore it apart. Kind of a silly design to make a critical contact that way, but maybe it has something to do with the position of the gear.
94 850 Turbo 189K
JDS60R
Year and Model: 2007 S60R 2007 S60
Postby JDS60R » Sat Feb 20, 2010 4:56 am
While you are in there you can clean the contacts with a pencil eraser (go lightly) . Leave the half circles alone . If you wish to replace the grease use any silicone grease like syl -glide or any dilectric compound. The placement of the grease is to keep the electricity from jumping from one circle to another.
Great job on the write up
Streetlight Insurance Brokers See what the market has to offer you !!!
Car, Home, Boat & Motorcycle Insurance in Tennessee
"Now its your turn to start saving"
Free VIDA Volvo code readings at my Mount Juliet, TN location
OUS
Year and Model: 850 turbo wagon 1995
Postby OUS » Sun Jun 06, 2010 12:25 am
Where and what is the damper motor?
Darksidechris
Year and Model: V70 1997
Postby Darksidechris » Thu Jun 24, 2010 7:59 pm
Hi all,
I would also like to know where the damper motor is as I have problems with my climate control and want to try this fix before replacing anything expensive.
Thanks for an amazing site and forums, I've read loads of very helpful stuff and excellent how-to guides.
Chris.
nightc1
Year and Model: 99'V70 Base 140K+Mi
Postby nightc1 » Thu Jun 24, 2010 8:52 pm
Darksidechris wrote:Hi all,
Chris.
It's behind the glove compartment and the lower dash panel on the passenger side.
Here's a thread with schematic pictures so you can see where it connects to the guts under there...
viewtopic.php?f=1&t=27974&p=123684
As for what it is... it's the thing that directs which ducts the air is going to go in the airconditioning/heating system.
V850B5254T
Year and Model: 2007 V70T aut
Flag: Denmark
Postby V850B5254T » Mon Oct 18, 2010 7:13 am
The use of silicone grease or oil in any electromechanical devices like potentiometers (as here) or relays is questionable.
Most silicone based products will produce Silicium Oxide (SiO2) if exposed to a spark and SiO2 is an excellent isolator.
When the wiper in the pictured example slides over the resistor half circle it will produce small sparks, not visible to the eye.
I would use a calcium stearate based grease or siilar like Luberex from GC for the potentiometer.
Silicone and electromechanical parts just does't mix.
oakey
Now:
Volvo 850T stc 1996
Volvo 940T stc 1998
Before:
Volvo 850 stc 1994
Volvo 240 stc 1988
Volvo 240 van 1981
Ford Granada Van 1973
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
V850B5254T
Flag: Denmark
Postby V850B5254T » Mon Oct 18, 2010 7:24 am
The grease shown in the picture was used to protect the plastic cog wheels from wear. It is possible that the grease has entered the potentiometer and caused your problem. However, it is more possible that scrapings from the half circle resistor on the PCB has clogged the connection between wiper and resistor.
Never use silicone products for electro mechanical parts.
I would use a calcium stearate based grease or similar like Luberex from GC for the potentiometer.
HAM radio homepages has a lot of information about how to handle and repair electronics.
oakey
Now:
Volvo 850T stc 1996
Volvo 940T stc 1998
Before:
Volvo 850 stc 1994
Volvo 240 stc 1988
Volvo 240 van 1981
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot], cn90, theneedforswede, tryingbe, Yahoo [Bot] and 57 guests
