Please don't use image hosting services like Image Shack. Here's why.
Having trouble logging in? Please delete http://www.matthewsvolvosite.com cookies in your browser. Here's how.
Why is my brake pedal so squishy?
nadz
Year and Model: 850, 1995 N/A
Postby nadz » Mon Mar 22, 2010 5:34 pm
Ever since I bought my 95 Volvo 850 I would have to basically push the brake pedal almost all the way down for the breaks to work, this is getting really annoying, pedal has to be pushed almost half way down for me to feel the breaks engaging.
Please let me know what could be causing this,
Thanks.
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Re: Why is my brake pedal so squishy?
Postby jblackburn » Mon Mar 22, 2010 6:05 pm
It sounds like you need a new master cylinder. Air is being let into/is circulating through the system, and much more pressure must be put on the pedal to activate the booster and force the fluid down the lines to squeeze the brakes.
This is dangerous from a personal experience I had with one...I would have it looked at or repair it as soon as you can.
'98 S70 T5
2012 Chevy Cruze LT 6MT
C@lvin
Postby C@lvin » Mon Mar 22, 2010 8:04 pm
jablackburn is probably right, but I'd look for other potential (less coslty) issues first. You didn't mention anything about your brake fluid. Is it at the proper level? Have you checked at each wheel for leaks? When was the last time the brake fluid was changed? Did you try bleeding the brakes to get any air out?
If there is no leak, but you don't know when the fluid was last changed, I'd try changing the fluid and see if that fixed it. It should be changed about every 30K anyway.
I definately agree that fixing this problem should be a very high priority since it's a life safety issue. In fact, if were mine I'd park it until it was fixed (although I realize this may not be an option for others).
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
IVIUSTANG
Year and Model: 2006 XC70
Flag: Canada
Postby IVIUSTANG » Mon Mar 22, 2010 8:11 pm
C@lvin wrote:jablackburn is probably right, but I'd look for other potential (less coslty) issues first. You didn't mention anything about your brake fluid. Is it at the proper level? Have you checked at each wheel for leaks? When was the last time the brake fluid was changed? Did you try bleeding the brakes to get any air out?
+1, this seems like the first logical process then go for the master cylinder if all else fails.
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000KM SOLD!
2006 XC70 320,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
nadz
Postby nadz » Mon Mar 22, 2010 10:02 pm
The brake fluid is at the proper level, I do not know of the fluid ever being changed, is it a difficult task to change out the brake fluid because I have no clue on how to do so,
charlyW
Year and Model: 97 855 T-5 CD
Postby charlyW » Mon Mar 22, 2010 10:10 pm
It's not a hard job to change the brake fluid just takes a bit of time. Couple of hours will do it but you will need a few essential items
Spanner to undo bleed screws 9 at the rear 10 front [going by UK Spec 850]
Suitable container to catch old brake fluid [jam jar works fine as long as you can prevent air going back up the pipe]
Suitable length of clear pipe to bleed the calipers off
You can buy numerous different bleed kits from simple to complex vacuum ones [vacuum ones take all the manual labour out]
couple of litres of brake fluid Dot 4 minimum NOT Dot 5.0 its silicone
Try to bleed the brakes off first to see if its just air you have in the system if it is you've saved money if not then it is possibly the master cylinder or a hard pipe.
bleed sequence 850.JPG (22.36 KiB) Viewed 951 times
You bleed the brakes by opening a bleed screw in sequence by a quarter turn and as you press the brake pedal slowly down it expells fluid and air along with any contaminates, once that caliper is thoroughly bled move to the next and repeat topping up the brake fluid bottle as you go. It is essential you dont allow air to return to the brake system so the pipe needs to be either in the old fluid or fitted with a suitable one way valve.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
Volvofix1
Year and Model: 1993 240
Postby Volvofix1 » Mon Mar 22, 2010 10:23 pm
Try pulling the master cylinder forward without disconnecting the brake lines,look at the rubber boot. If it is wet with brake fluid,the master cyl. is N.G. Good luck
polskamafia mjl
Flag: Poland
Postby polskamafia mjl » Tue Mar 23, 2010 2:33 am
Couples of hours seems like a little overkill. :D I would say hour and half for the first time at most.
nadz
Postby nadz » Fri Apr 02, 2010 7:07 am
I bled the brakes today with a friend (there was no air in the system since the fluid came out in a nice stream), but still the pedal feels the same I have to push it far down to brake, my friend says it's not the master cylinder? Could it be because I barely have no rear brakes?
phils94850
Year and Model: 96 850 Platinum
Postby phils94850 » Fri Apr 02, 2010 7:31 am
thats probably the winner ! LOL. If you have very little pad left then then your having to push further down on the pedal to get the pads to contact the rotors giving you the low pedal feeling.
Id say, put new pads on the car and go from there. Volvo's are known for having noisy brakes so make sure you have the rotors turned if they look mirrored, and use anti-rattle grease on the pads and that'll help keep down the squealing.
My wifes s70 would squeal alot, i took the brakes apart and applied anti-rattle grease and no more squeal :).
Heres a great write up on brake repair...
http://www.volvospeed.com/850rbrake1.php
1996 Platinum Edition
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: 1337, coolpilot, sleddriver and 32 guests
