Please don't use image hosting services like Image Shack. Here's why. That's from 2009, and it still holds. The forum software is better than ever at uploading and storing photos, and it's easy.
1998 S70 GLT Transmission not shifting
dacts59
Year and Model: 1998 S70 GLT Sedan4D
Postby dacts59 » Mon Apr 19, 2010 4:19 am
The car goes forward but only stays in gear about ten minutes then it will not shift gears anymore, I can not get it to go in reverse at all. I did take about 3 quarts of extra transmission fluid out (courteous of previous owner). Would a transmission flush help? Is there electronics in the transmission that may be causing the problem? I do get the arrow indicator light, when the transmission stops going into any gear. Once engine has cooled it will then work again in forward gears but still no reverse.
jblackburn
Year and Model: 1998 S70 T5
Re: 1998 S70 GLT Transmission not shifting
Postby jblackburn » Mon Apr 19, 2010 4:27 am
:( I think it's dead. Usually no reverse is a pretty bad sign.
Nonetheless, try a transmission flush. Pump all the fluid out from the top radiator line until you get air bubbles, then refill about 3 qts or so, and re-check the level.
If the fluid is horribly discolored, go through the whole flush procedure with 12 qts or so of fluid - search the site here for 'transmission flush' for a how-to.
'98 S70 T5
2012 Chevy Cruze LT 6MT
BigRed
Year and Model: V70R 1998
Postby BigRed » Mon Apr 19, 2010 11:43 am
You said you are getting the up arrow, I assume it's blinking? Is the MIL also on? Can you read the codes or get it to an AutoZone/Advance Auto Parts to get the codes read?
dacts59
Postby dacts59 » Tue Apr 20, 2010 9:27 pm
Havn't read codes yet, will take me a couple of day to get it down to Auto Zone .
jblackburn
Postby jblackburn » Tue Apr 20, 2010 10:05 pm
Do the reverse lights come on when the gearshift is put in reverse?
I suppose it COULD be the PNP switch, but it should be going into limp mode (3rd gear) instead of not forward at all.
There is a small filter at the pump pickup that is un-replaceable; it sounds like either this is clogged or the valve body solenoid is dead (also un-replaceable) without removing the transmission from the car.
Un-replaceable, is that a word? Hmm...
'98 S70 T5
dacts59
Postby dacts59 » Thu May 13, 2010 2:24 pm
The Transmission flush did help, but still will not go into reverse, I agree with the solenoid diagnostics and small filter at pump should be check and repaired. Now looking for a Transmission shop that would not take me for all my money, any body have a good est price of this transmission repair should cost? Attempt to do it myself, but need to complete building my shop first a 22x 30 dream.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: cn90, FastYellow, gmh, Ringo, sleddriver, tryingbe and 25 guests
