Maf sensor 94 turbo drives fine disconnected!
Free2drive!
Year and Model: 855 T5 auto 1994
Postby Free2drive! » Wed Jul 14, 2010 9:15 am
Hello
Before spending out on a new maf, what do you think of this situation?
My 94 turbo drives fine with the maf sensor disconnected, it throws a code but when I reconnect the maf sensor and clear the code it drives no differently.
I thought when the mad was bad it would cause stumbling and stalling?
So is my maf bad?
Matt
Thanks
Matt
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Re: Maf sensor 94 turbo drives fine disconnected!
Postby jblackburn » Wed Jul 14, 2010 11:49 am
Clean the connector on both ends, and then re-fasten it with a zip tie and see if your code comes back.
'98 S70 T5
2012 Chevy Cruze LT 6MT
pkc303
Year and Model: 850R 1997
Postby pkc303 » Wed Jul 14, 2010 2:15 pm
What code do you get?
1997 Volvo 850R, K&N air filter, Koni shocks
1995 Volvo 850 T-5R Yellow
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
polskamafia mjl
Flag: Poland
Postby polskamafia mjl » Wed Jul 14, 2010 7:29 pm
A bad MAF sensor will generally manifest itself by making the engine run poorly while it is plugged in, and making the engine run fine when it is unplugged. So from your description, your MAF sounds fine. But, as stated before, what code do you have?
Free2drive!
Postby Free2drive! » Wed Jul 14, 2010 8:25 pm
I'm getting code 1-2-1 from A2. If I reset the code and restart the car it revs up to 1500 then nearly stalls and instantly returns to 900 rpm. The car then drives fine with or without the MAF sensor connected.
Matt
jblackburn
Postby jblackburn » Wed Jul 14, 2010 8:47 pm
Most likely you need a new sensor, but try pinching the connector on to it with your hand while someone else starts the car.
'98 S70 T5
Free2drive!
Postby Free2drive! » Thu Jul 15, 2010 8:58 am
This is strange!
We swapped out the maf from a u-pull and the car drives like it's on steroids. Total difference and no codes. We took it from a 95 t5 90,000 miles.
Both the replacement maf and my old maf have different part no's!!!! Both are made by Bosch and both look identically except the new one has a larger aluminium block by the sensor strip.
As soon as it stops raining I'll get out and post both part no's.
Thanks
Matt
jblackburn
Postby jblackburn » Thu Jul 15, 2010 12:08 pm
My guess would be that you have an early '94 model, which are a bit strange all by themselves. If the new sensor works OK, it is just an updated version - don't worry that they look slightly different.
I would reset the computer adaptives by pulling the battery cable and draining the charge (hit the brake pedal a few times) and let it re-learn the "right" way with the new sensor installed.
'98 S70 T5
Free2drive!
Postby Free2drive! » Thu Jul 15, 2010 9:42 pm
Thanks
I did disconnect the battery for a couple of hours before driving with the replacement MAF, it really is a different car. Much more power and go like my old 1997 T5.
Anyway, the part no of the MAF that I think is either faulty or the wrong one - 0 280 217 1073 507 697
The part no of the MAF that I pulled from a 95 T5 - 0 0280 217 1071 275 749
Both are made by Bosch.
Does anyone know the correct car for the first MAF?
Thanks
Matt
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: angelglo, AtomicForces, jonnycycles, kranz, MSNbot Media, PS78, shagginwagon850 and 42 guests
