RSS feed for Volvo Blog and Repair Database Follow MVS on Twitter!
1998 S70 windshield washer cap missing
Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
1997 - 2000 C70
Postby vtcarol502 » 28 Jul 2010, 06:47
Could this cause the check engine light to comeon. Also I was told that it leaks as well when filled. Should this reservoir be replaced? If so, how would you do it? Any pictures or diagrams would be appreciated.
vtcarol502
New Member
New Member
Model, Year: 1998 S70
Re: 1998 S70 windshield washer cap missing
Postby jablackburn » 28 Jul 2010, 07:22
No. It will leak at the filler neck if it is filled past that; that's pretty normal. Aluminum foil & a rubber band will work as a cover for now; you can find one off a junk car or something to put on there.
I'll get you a diagram later on today when I have my computer with me.
'98 S70 T5 178K miles - K&N filter, IPD HD TCV, Mobil-1
"You may not end up where you thought you'd be, but you always end up where you're meant to be."
jablackburn
Model, Year: '98 S70 T5
Postby vtcarol502 » 28 Jul 2010, 12:30
Thank you for your response. I noticed that their is a hose disconnected at the windshield washer reservoir that is leaking the fluid into the car, should this be connected to something else on the reservoir?
vtcarol502
New Member
New Member
Postby JRL » 28 Jul 2010, 14:00
Not always true
They can and DO crack at the bottom
No check engine light but you will get a low washer fluid light
1999 V70 T5M 1 of 20 White (almost finished)
2000 V70R Black 88K miles (Wife's)]
2000 V70R Silver, 28,000 miles!!! LIFETIME KEEPER
1998 S70T5M Tropic Green, unreal, for sale soon
JRL
Senior Member
Senior Member
Postby ecbsykes » 28 Jul 2010, 15:01
vtcarol502 wrote:Thank you for your response. I noticed that their is a hose disconnected at the windshield washer reservoir that is leaking the fluid into the car, should this be connected to something else on the reservoir?
I had this same problem too. There are a couple check valves throughout the system there, and for me it was just a matter of plugging a loose hose back into one of the valve. In my case it was because I was getting no fluid to the rear wiper. When I hit the button I'd simply get a waterfall of fluid pouring from the pump/reservoir area.
And if you want a new reservoir cap you can get them at eeuroparts.com or a dealer... they're cheap.
Ed Sykes
2000 V70XC 2.4L Turbo - Emerald Green -145,000 miles
Lubro-Moly 5W-40 Full Synthetic - Made In Germany!
United States Air Force ROTC
Northern Arizona University
***Gone to AFROTC Field Training July 31 - August 28***
ecbsykes
Senior Member
Senior Member
Model, Year: 2000 V70XC
Postby jablackburn » 29 Jul 2010, 14:33
If you do need to replace the tank, here is the diagram for you:
Several screws have to be got to from under the car, and then it will lift right out.
windshieldwasher.pdf
(47.83 KiB) Downloaded 13 times
jablackburn
Postby vtcarol502 » 29 Jul 2010, 22:53
thank you for the diagram, it makes more sense to me now having this.
vtcarol502
New Member
New Member
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: BEJinFbk, ecbsykes, farmer66, junopen, Kuhnman, mindshadow, oh-la-la, pkc303, silversleeves, Yahoo [Bot] and 57 guests
Click to go to Denver's Premiere Volvo Shop
Click to go to Discountvolvoparts.com
