VOLVO 850 t5 (1996) breather blocked?
850t5turbo
Year and Model: 850 1996
Postby 850t5turbo » Fri Sep 17, 2010 9:52 pm
Hi everyone,
I need some very urgent advice please?
I recently could smell oil burning and when i lifted the hood noticed that smoke was coming out of the dipstick. It was not that heavy or anything like that but something that was not there when i bought the car 4 years ago.
Now a bit about the car - it has done 130k miles and goes like a rocket! It is the standard 225bhp. The oil pressure light goes straight out when the car is first started and any other time that it is started, so no problems there. It does not show any blue smoke or any other colour smoke out of the exhaust. It has just passed its MOT - went straight through and passed on emissions etc etc.
Now what i have been quoted! Been told that the breather box/pipes may be blocked and the garage (volvo garage) are asking £280 to fix the problem. Is this price about right? Also what sort of job is this - is it a big job?
Someone once told me that a blocked breather would have adverse effects on the performance of the car but the garage said that this would make no difference to performance or to fuel economy. What would happen if i were to leave this problem - would any harm incur? Would i break down eventually or cause any other mechanical probs?
Please, any answers would be much appreciated??? Many thanks for all your time and help..
Kind regards,
Simon
Reason: Redundant question marks removed from title.
MNCO1
Year and Model: 850 T-5 1997
Re: VOLVO 850 t5 (1996) breather blocked????
Postby MNCO1 » Fri Sep 17, 2010 10:11 pm
Sounds like a PCV cleanout/overhaul and 280 pounds sounds like too good a deal, wonder what they do? Check out " PCV System Repair on a Volvo 5-cylinder"by jablackburn. Its on the 850 main menu. It will give you an idea of what comes apart and gets replaced. I know the breather box as an oil separator. Aside from replacing the oil separator I am sure sure some hoses could be replaced too. A build of gases could lead to rupturing the cam seals and rear main seal. Causing engine oil to leak in varying degrees.. The latter would prove to be very costly to replace.
JRL
Year and Model: Several
Flag: United States of America
Postby JRL » Sat Sep 18, 2010 2:21 am
3+ hour job
$175 or so in parts (Volvo retail)
Good deal
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
pkc303
Year and Model: 850R 1997
Postby pkc303 » Mon Sep 20, 2010 12:49 am
Yeah, you got a PCV, or what Volvo calls the Flame trap system, that needs to be replaced. You can find the tutorial on here, but I would allow at least 3 hours of steady work, or a day if you take breaks. We spent two days doing it, because I wasn't sure which parts I would need to replace. I ended up replacing more hoses that normal, due to their cracking as they become more brittle when they age. We've done it on both 850's. It's fun.
1997 Volvo 850R, K&N air filter, Koni shocks
1995 Volvo 850 T-5R Yellow
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
charlyW
Year and Model: 97 855 T-5 CD
Postby charlyW » Mon Sep 20, 2010 7:05 pm
You'll find two pipes that connect from the block will be blocked. Not a hard job just time consuming and volvo clips are fun to remove. That is a good price from a volvo agent you can get cheaper by a specialist and any good garage can do the job as it's a case of removing the inlet manifold unbolting the oil seperator, removing the pipes and refitting You could do the complete job in an afternoon
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
jblackburn
Year and Model: 1998 S70 T5
Postby jblackburn » Mon Sep 20, 2010 7:15 pm
MAKE SURE THEY CLEAN THE PORTS ON THE ENGINE BLOCK!!! (and the PTC nipple)
Or the whole cleaning will be pointless :(
'98 S70 T5
2012 Chevy Cruze LT 6MT
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: BEJinFbk, erikv11, rax_tempus, Sommerfeldt and 25 guests
