poo14 error code
wilfster
Year and Model: V70 1999
poo14 error code
Postby wilfster » Sun Nov 21, 2010 5:06 pm
Hi,This is my first post soooooo......
I have recently changed the cylinder head on my 1999 V70 2.5t (b5254t engine), I have checked various online tutorials regarding timing marks,etc BUT can't find any regarding this particular engine.
Anyhow,here's the problem I'm having.....
1.starts fine
2.idles fine
3.after about an hour rough idle appears/misfire
4.error code p0014 shows with my diagnostic tool.
5.it will reset but only for about 2-3 seconds then rough idle again
6.No ETS light,NO check engine light
7.?????????
I'm flumuxed,is there something i'm missing or is it time to take it to volvo??
BTW car was bought as non runner(due to cylinder head).
I have found the timing marks on the crank(two small notches either side of TDC) and the inlet sprocket points straight up,the exhaust was lined up by using the end of the camshaft and th joint between the cylinder head and the top of the engine.
Any ideas??
JRL
Year and Model: Several
Flag: United States of America
Re: poo14 error code
Postby JRL » Sun Nov 21, 2010 5:58 pm
Cam code
You may be one tooth off on your timing
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
wilfster
Postby wilfster » Sun Nov 21, 2010 7:54 pm
Thanks for your prompt response, I will double check on the weekend.
Do you have any pics of b5254t engine timing marks??
I don't understand how vvt works with what's essentially a vernier pulley?
But why would it run ok? then run rough?
thanks
wilfster
jblackburn
Year and Model: 1998 S70 T5
Postby jblackburn » Sun Nov 21, 2010 11:01 pm
The VVT can let the exhaust camshaft rotate up to 30 degrees to adjust low-end torque/high-end power and get better fuel economy while doing it (something the 5-cylinder needs a bit of help with). It may be when that's activating that the rough running starts.
To set the timing on a VVT engine, you need to rotate the camshaft past the mark slightly, and then come back and line the marks up. If you didn't do this, then most likely your timing is now off by a tooth or two.
See the directions for tensioning the timing belt on a VVT engine in this S60 - the same procedure applies for your car.:
viewtopic.php?f=9&t=22659
'98 S70 T5
2012 Chevy Cruze LT 6MT
wilfster
Postby wilfster » Mon Nov 22, 2010 8:00 pm
Thanks for you response and info,But I'm still not sure of a few things..
1 Why is there some fine adjustment on the exhaust pulley?
2. I have lined up the "other ends" of the camshaft withe cylinder head,so do i now ignore that bit?
3.Or do i just line the the pulley up one/two teeth out(????) clockwise or anti clockwise.
I will follow the instructions that you kindly sent to me But with almost a full tooths movement within the exhaust pulley,what datum should i use?
Thanks in advance...no pun intended(P0014).
jblackburn
Postby jblackburn » Mon Nov 22, 2010 10:04 pm
All you should have to do is rotate it past slightly, and then rotate back and line up the marks with the cylinder head. Make sure #1 is at TDC first; then go at it.
'98 S70 T5
wilfster
Postby wilfster » Mon Nov 22, 2010 10:14 pm
Ok,thanks
One last thing....judging by the instructions all/most of the slack in the belt is around the exhaust pulley.
And to double check...why is there the fine adjustment thingy on the pulley?
TIA
jblackburn
Postby jblackburn » Tue Nov 23, 2010 1:05 am
You might want to shoot JDS60R a PM...he knows much more about the VVT/newer models than I (my model doesn't have that). He's a very helpful/knowledgeable guy ;)
'98 S70 T5
wilfster
Postby wilfster » Tue Nov 23, 2010 6:00 am
Cheers,will do.
JDS60R
Year and Model: 2007 S60R 2007 S60
Postby JDS60R » Tue Nov 23, 2010 10:44 pm
Try the attached procedure.
If it is set correctly and your P0014 continues then do this
1. Use a quality engine oil flush
2. Change filter and oil using a semi synthetic at least
3. Replace outdated gasket under VVT control valve with updated one with metal filter in it.
4. Clean VVT valve while off with parrafin
Run and test.
1999 B5254T V70 XC VVT and cam belt replacement procedure.pdf
(862.72 KiB) Downloaded 103 times
Streetlight Insurance Brokers See what the market has to offer you !!!
Car, Home, Boat & Motorcycle Insurance in Tennessee
"Now its your turn to start saving"
Free VIDA Volvo code readings at my Mount Juliet, TN location
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: BEJinFbk, Bing [Bot], ChapmanMFG, erikv11, Google Adsense [Bot], Herb Goltz, james321, jamesbeat, Matty Moo, misha, PS78, scot850, shaker_chi, Sommerfeldt, styoung94, v-45magna, volvomax, xHeart and 51 guests
