ABS light now on after battery disconnect
johnnchrisr
Year and Model: S70 T5M, 1999
Postby johnnchrisr » Fri Dec 10, 2010 9:22 am
Hi again all,
I just replaced the instrument cluster bulbs in my '98 S70 and before getting started, disconnected the negative battery terminal. Upon hooking the battery back up and starting the car, I now have the ABS light illuminated constantly. I should note that I tested the bulbs without the dash back together to make sure they all worked, and when I reconnected the battery and started the car that first time, no ABS light. It was only after disconnecting the battery again, reassembling everything and reconnecting the battery that I got the light that is now chronic. I also tried disconnecting the battery again to no avail. I just replaced the ABS module a couple of weeks ago (car is new to me and I knew it needed to be done since both the ABS and TRACS lights would come on intermittently; the new module cleared that up and I confirmed ABS indeed worked), so I know that's OK. I have a feeling the light just needs resetting, but what a pain.
Any ideas?
Thanks,
Chris
1998 S70 Base, Silver, 103k miles
2001 C70-C LT, Silver, 134k miles
Matty Moo
Year and Model: 850, 1996
Flag: United States of America
Re: ABS light now on after battery disconnect
Postby Matty Moo » Fri Dec 10, 2010 2:11 pm
Are you getting just the ABS light, or both ABS and TRACS?
Generally, the lights won't come on from disconnecting the battery, but stranger things have happened.
check your harnesses going to the module. Make sure the smaller one is completely bottomed out, and reseat the large multi-pin harness a few times.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1998 S70 ARD tune, EST exhaust, SE/R interior.
1999 S70 Plain Jane.
2000 S70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
jblackburn
Year and Model: 1998 S70 T5
Postby jblackburn » Fri Dec 10, 2010 2:40 pm
Once you check the wiring, just take it for a drive if you haven't yet since resetting the computer. The ABS system will automatically reset itself once you go over 20 mph and it determines everything's ok.
'98 S70 T5
2012 Chevy Cruze LT 6MT
thecheat
Year and Model: 1996 850 Turbo Wagon
Postby thecheat » Fri Dec 10, 2010 5:09 pm
Obvious question here but did you reconnect the passenger airbag?
johnnchrisr
Postby johnnchrisr » Fri Dec 10, 2010 8:15 pm
Thanks for the replies. I checked the harnesses and have driven about 12 miles at speeds up to 50 mph, but the light remains. TRACS light is not on, and ABS stays on (does not go off/come on). Before replacing the module, the ABS and TRACS lights coming on/going off was a symptom. The question about the airbag is an interesting one - yes, I did reconnect, but the ABS light coming on might have coincided with a marginally-connected ground strap when I was testing the bulbs before dash reassembly. I did not think the two were at all related, but could they be?
johnnchrisr
Postby johnnchrisr » Fri Dec 10, 2010 8:28 pm
And by "ground strap", I mean the one for the passenger airbag.
johnnchrisr
Postby johnnchrisr » Thu Dec 30, 2010 3:03 am
In the interest of closing the loop, I'll let you all know what I discovered. Besides the ABS light staying illuminated, the left turn signal indicator didn't work, and neither did the rear fog light indicator. Thinking this was strange, I removed the dash cover again and voila - there it was - one of the three harness to the cluster not even plugged in (oops!). After plugging it back in, all is well.
Chris
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: gmh, MSNbot Media, scot850 and 34 guests
