Jerky power steering
volvosrock
Year and Model: 1998 S70
Postby volvosrock » Fri Jan 14, 2011 6:04 am
I have a 98 S70 GLT, 160k.
I just bought the car a couple of weeks ago, and i noticed the power steering is jerky (or maybe "it sticks" is a better way of describing it). Its not smooth at all, and it's hard to make the small adjustments on the freeway to stay in the middle of the lane. I thought if i drove it for a while it would go away, but its not.
It just so happens that last week i drove my brothers car for the first time, (S70, same everything) and noticed that it did the same thing. Is this normal for these cars, or what? We've both upgraded from 850's, and they never had this problem that i can remember. Should i flush the power steering fluid?
IVIUSTANG
Year and Model: 2006 XC70
Flag: Canada
Re: Jerky power steering
Postby IVIUSTANG » Fri Jan 14, 2011 6:30 am
Yes, flush it. Mine used to do that then I flushed and filled with mobil 1 synthetic(dex III) and it is like butter now. I'll also mention that my old mishapen tires for me caused the exact same symptom as a notchy power steering rack. I love the steering on my car after those two problems were rectified!
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000KM SOLD!
2006 XC70 320,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
volvosrock
Postby volvosrock » Fri Jan 14, 2011 3:38 pm
OK cool, thanks for the reply.
how exactly do i flush it? Just pull the line and pour it in as its coming out as the car's running?
Does it hurt the system to run it dry?
And my other question is, how does the conversion to synthetic work? obviously there's some of the old fluid left in there...
thanks!
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Postby jblackburn » Fri Jan 14, 2011 3:41 pm
Turkey baster! Suck the fluid out, refill, and run lock to lock a few times, then shut it off again and repeat 4-5 times.
Don't let it run dry. Air gets stuck in the system.
'98 S70 T5
2012 Chevy Cruze LT 6MT
IVIUSTANG
Flag: Canada
Postby IVIUSTANG » Fri Jan 14, 2011 6:53 pm
Or, the way I did it is to first empty the reservoir, then remove the return hose to the power steering reservoir, clamp an extension hose onto it so you have a good length. Then run the hose to a 1 gallon milk jug and put it beside the drivers door so you can see it as you turn the steering wheel. Plug the fitting where the return hose connects to the reservoir then fill the reservoir up with new fluid.
I then jacked up the front of my car as I didn't want weight on my tires as I turned the steering wheel with my car turned off(not 100% nescesary but I liked doing it), but with the ignition on so my steering is unlocked.
From this point it's just a matter of turning lock to lock until you see the shiny red new fluid come out of the hose into the milk container.
You'll want to continually add new fluid to your reservoir so it doesn't run dry during the process.
This is how I did it and it's kind of like bleeding brakes in the fact it doesn't really mix up the old and the new fluids, this will give you the most pure fluid possible in your steering system.
- Jesse
Marcobrick
Year and Model: 850R 1996
Flag: New Zealand
Postby Marcobrick » Fri Jan 14, 2011 7:43 pm
Some of the symptoms you describe are similar to mine. You must have just submitted this thread as I was typing mine! ("Peculiar Power steering") I will watch with interest to see if the flush cures your symptoms.
1996 850R
2004 Mitsubishi Grandis
1994 Daihatsu Rocky Turbo Diesel
1976 Triumph 2500TC
1973 Sunbeam Sceptre
Previously:
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
volvosrock
Postby volvosrock » Sat Jan 15, 2011 3:42 am
So i did a partial flush this afternoon with Dex III.
I used a pump from a used container of hand soap...
(maybe those fancy bath and body works soaps are worth something after all! lol)
I only got like less than a cup per time (and per 50-60 pumps) from the reservoir because its so shallow, so i only ran 1 quart through the system. I used an old motor oil can and held it under the pump spout. Kind of ghetto, but hey, it works! (-:
I'll probably do it again tomorrow, but what a difference! The problem's not all gone yet, but i'm sure with another quart or two, it should clear up completely.
Thanks for the help everyone!
kcodyjr
Year and Model: 1997 850 GLT
Postby kcodyjr » Sun Mar 20, 2011 8:25 pm
I'd swapped my P/S pump and let a whole bunch of air into the system, and was about to do this, and then realized it only takes an hour or so of sitting still for the bubbles to work themselves out of the reservoir.
So, I'd start it, work it lock to lock just once and leave it centered, then shut it off and wait.
In 3 cycles, the pump was quiet from lock to lock.
I believe the key was only working the wheel once, so the foamy stuff came up into the reservoir and stayed there.
1997 850 GLT sedan, 152K and WHOOHOO!
RIP 1996 850 wagon, 201K, hit by a runaway 4-wheeler
RIP 1996 850 GLT sedan 5spd, 260K, rearended someone
RIP 1986 245 boring, 200K, rusted beyond inspectability
RIP 1981 242 turbo 5spd, 300K, serious teenage crash
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot], mecheng, MSNbot Media, noev70t5, tryingbe, Yahoo [Bot] and 28 guests
