Please don't use image hosting services like Image Shack. Here's why. That's from 2009, and it still holds. The forum software is better than ever at uploading and storing photos, and it's easy.
srs light
kerleyg
Year and Model: s70, 99
srs light
Postby kerleyg » Mon Jan 17, 2011 9:19 pm
Hello guys and gals,.....I recently replaced the ac evap and heater core, and now my srs light is staying on....could someone out there please help me with this problem so my wife can drive car without worry.....greg.
jimmy57
Re: srs light
Postby jimmy57 » Mon Jan 17, 2011 9:50 pm
Did you have key on enough that radio played any time the air bag connectors were loose?
The SRS is active if radio will play (key pos I).
You will have to have someone with diagnostic tool for that car that can do all systems. There is no non scanner way to clear SRS codes on that car.
kerleyg
Re: srs light
Postby kerleyg » Mon Jan 17, 2011 9:57 pm
So, Jimmy57, are you saying that I have to take car to a shop, or to the dealer to have it reset, or would I have to buy a diagnostic tool to try and reset SRS light.....and I wonder why it came on in the first place,....????....greg.
Year and Model: Many Volvos
Flag: United States of America
Re: srs light
Postby Ozark Lee » Mon Jan 17, 2011 10:01 pm
There can be two reasons the SRS light came on, either you didn't disconnect the battery before you disconnected the SRS connectors or there is an SRS plug that isn't plugged back in. Assure that the steering wheel airbag and the dash air bag are plugged in and then you will need to get the light reset.
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
JRL
Year and Model: Several
Re: srs light
Postby JRL » Mon Jan 17, 2011 10:12 pm
...and dealer only for reset, an OBD reader cannot clear it
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
kerleyg
Re: srs light
Postby kerleyg » Mon Jan 17, 2011 10:21 pm
Is there a pic or a diagram showing how connectors are supposed to look before disconnect,....I thought I had them reconnected correctly.....I know it does not show in Haynes manual.....greg.
jimmy57
Re: srs light
Postby jimmy57 » Mon Jan 17, 2011 10:52 pm
Did you have steering wheel off? Did you disconnect the connectors for the turn signal switch and other things on top of steering column?
The RH airbag has a connection directly on the bag and another a few inches away from bag. Which did you disconnect?
There are airbag connectors below each front seat. Did you have anything apart for any reason?
OBD-II scanners that are so plentiful read only engine management and some transmission info.
VIDA or older VADIS tools from Volvo will of course read and clear whole car but there are other tools out there that do it too. Autodiagnos is one of those that some Indy shops use.
kerleyg
Re: srs light
Postby kerleyg » Mon Jan 17, 2011 11:04 pm
I took the steering wheel off, and I now cannot remember where the screw holding orange strap screwed into.....I noticed there was a screw hole in plastic part of wheel and another by base of steering wheel past 18mm nut....I did not mess with seats....I did disconnect battery before removing wheel.....greg.
kerleyg
Re: srs light
Postby kerleyg » Mon Jan 17, 2011 11:09 pm
the hole for screw was metal on the second part and when I screwed screw in it hampered the turning of wheel.....sort of like a stop or something.....I just wished the manual had more to offer.....greg.
Re: srs light
Postby Ozark Lee » Mon Jan 17, 2011 11:43 pm
I don't know if you used this but it is quite precise on doing an evaporator change on an 850 series car. I don't know how different things are on your '99 since I have never touched one.
http://www.woodjoiner.com/volvo/
I'm sure many things are identical.
Please post any further questions and responses in the appropriate forum (1992-2000). The general discussions forum is not for specific problems. I have moved you last posts to that forum where they will get the appropriate attention but after about 2 weeks they will be deleted from the general discussion forum.
'98 S70 T5
'96 850 N/A
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: cn90, FastYellow, gmh, Google Adsense [Bot], Ringo, sleddriver, tryingbe and 28 guests
