Please don't use image hosting services like Image Shack. Here's why. That's from 2009, and it still holds. The forum software is better than ever at uploading and storing photos, and it's easy.
1996 850 not starting. (alarm issue?)
Sofija
Year and Model: 1996 850
Postby Sofija » Sat Jan 22, 2011 4:26 am
I have a 1996 850 and have never had this problem before.
The car has been working fine. Yesterday, I get in, go to start it and nothing happens.
The lights, stereo, etc. work but the car won't start.
The battery died a couple weeks ago and I bought a new one through AAA so I called them thinking it may be a battery issue. They sent someone out and said the battery and alternator were fine.
He said he has seen this before in cars and that it sometimes has to do with the alarm disengaging.
I bought the car used and it did not come with a keyless entry remote. I didn't even know I had an alarm until it would randomly go off when I open the drivers side door with the key. It would sound and to stop it, I would lock and unlock the car again.
I read the manual and looked up some things online but nothing worked.
I am completely stumped and would love to avoid a trip to the mechanic. (This has has cost me some money!)
If anyone might have an idea as to what is going on, or can offer a suggestion, I would appreciate any input.
I do realize this might have zero to do with the alarm, but like I said, right now I am pretty stuck.
Thank you so much!
-Sofi
Year and Model: Many Volvos
Flag: United States of America
Re: 1996 850 not starting. (alarm issue?)
Postby Ozark Lee » Sat Jan 22, 2011 10:57 am
Welcome to MVS,
Does the car crank and not start or just not crank at all? The alarm / immobilizer prevents the car from cranking at all so if it is cranking the problem is not with the alarm.
Even without the remote keyfob you can normally reset the alarm by closing all of the doors and using the key to lock it a couple of times and then unlock it a couple of times.
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
gilhuly
Year and Model: 97 850R
Postby gilhuly » Sat Jan 22, 2011 2:56 pm
Why would you not begin with diagnosing the starter? I'd like to know how the AAA guy OKed the alternator without starting the vehicle, not that I think it has anything to do with anything here.
Smack the starter with a rod or a broom handle or something while a partner turns the key. If it comes to life you have a bad starter and a straightforward fix.
1998 V70 GLT, 15G swap
Fairfield, CT
holler1
Postby holler1 » Sat Jan 22, 2011 3:47 pm
Sofija wrote:I have a 1996 850 and have never had this problem before.
I'm reading this ("nothing happens") to mean the starter doesn't crank. If so, the problem could also be in the wiring to the starter, the starter/solenoid itself, or in the key switch. So you need to narrow it down. Banging on the starter may help if the starter is at fault. If locking/unlocking the door several time doesn't work, try rowing the shift lever back and forth a lot of times. That should help if the problem is in the PNP switch (if the car is auto trans).
If none of these things help, post back. If you can use a voltmeter, there are some other things to check.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
jimmy57
Postby jimmy57 » Sat Jan 22, 2011 3:54 pm
I would try moving the gear lever to N and even moving the gear lever slightly for aft in P and N positions while key is held over in the start position. The starter circuit passes through the gear position sensor/neutral safety switch assembly on the gearbox and those electrical contacts do wear out.
Another thing: lights, radio, etc. coming on is not the most accurate way to check battery condition. If you can get jumpered by a friend or neighbor and it might start. If so then you do need to get a more thorough check of charging system.
Sofija
Postby Sofija » Sun Jan 23, 2011 2:27 am
Postby Ozark Lee » Today, 03:57
Welcome to MVS,
Thank you for the welcome!
The car does not crank at all.
I have tried locking and unlocking the doors as well.
I have never had this issue before, it's quite frustrating.
Sofija
Postby Sofija » Sun Jan 23, 2011 2:29 am
* Report this post
* Reply with quote
Postby gilhuly » Today, 07:56
Sorry I didn't make that more clear, when they put in the new battery a couple weeks ago they said the alternator was fine.
"Smacking" the starter is not going to break anything? I'll give it a try!
Sofija
Postby Sofija » Sun Jan 23, 2011 2:33 am
* Report this post
* Reply with quote
Postby holler1 » Today, 08:47
1998 Volvo V70 AWD 150000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 27500
1998 Tacoma, Fords (5), Dodge, Montero,
You are correct, the starter doesn't crank. I will definitely give the shift lever a try (yes, it is an automatic).
*crossing fingers*
I appreciate all the replies.
Sofija
Postby Sofija » Sun Jan 23, 2011 2:36 am
* Report this post
* Reply with quote
Postby jimmy57 » Today, 08:54
AAA told me yesterday it wasn't the battery. I didn't want to assume just because the lights were working that the battery was fine.
I really appreciate all the help here.
The only thing that stinks is it's 12 degrees outside so messing around with my car is the last thing I want to be doing right now! But I'm going to go give a few of these suggestions a shot!
Pauloil
Postby Pauloil » Sun Jan 23, 2011 3:22 am
got a voltmeter? might be bad starter cable, batt to starter check cables before alt.
volvo wires (cables) are checked at 2K rpm with headlights on and rear defroster and fan on high
normal voltage drop in less than 0.2 volts... It is like asking "how much voltage can't get thru the wire?
http://www.aa1car.com/library/voltage_drop_testing.htm
99 V70XC 158K
95 850glt 188K
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: 98v70dad, matthew1, misha, SonicAdventure and 29 guests
