Front cam/crank shaft seal replacement
aahmes57
Year and Model: S70 Turbo 1998
Postby aahmes57 » Thu Feb 24, 2011 6:16 pm
I'm leaking oil again.
I can't seem to find a good write up w/ pics for the front cam/crank shaft seal replacement.
Does anyone know if good DIY repair is out there somewhere?
Thank you
1991 740 (saved a life)
1998 S70 Turbo
1995 850
1999 V70 Base
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Re: Front cam/crank shaft seal replacement
Postby jblackburn » Thu Feb 24, 2011 6:32 pm
This and Ozark's timing belt change procedure should help you.
camseals98.pdf
(710.17 KiB) Downloaded 1277 times
'98 S70 T5
2012 Chevy Cruze LT 6MT
aahmes57
Postby aahmes57 » Thu Feb 24, 2011 7:47 pm
Thanks briefly it looks great.
1998 S70 Turbo
1995 850
1999 V70 Base
Year and Model: Many Volvos
Postby Ozark Lee » Fri Feb 25, 2011 1:58 am
The front seals are difficult to remove and replace due to the proximity of the front of the camshafts to the strut tower and the ECU box on the exhaust side and intake side respectively.
One other potential snag is the adjustable cam timing. The cam sprockets have slotted bolt holes and they can be adjusted. In my case I used some spray paint to mark the bolt positions so that I could get the timing on the sprockets back to their stock positions.
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
aahmes57
Postby aahmes57 » Fri Feb 25, 2011 7:38 pm
Thanks Lee. Do you know where your write up is that jblackburn is referring to?
1998 S70 Turbo
1995 850
1999 V70 Base
jblackburn
Postby jblackburn » Fri Feb 25, 2011 7:47 pm
It's titled '850 140K major maintenance' as a pinned thread in the forum.
Here ya go.
viewtopic.php?f=1&t=19831
'98 S70 T5
Year and Model: 1998 S70 GLT
Postby cn90 » Wed Aug 01, 2012 3:27 pm
Hey guys,
Is it the consensus here that the FRONT CRANKS seal never leaks (it is part of the Oil Pump BTW)?
If so, then I won't bother with it during the next TB change at 120K.
PS: This tutorial has all the wonderful steps/pictures:
http://www.tracystruesoaps.com/tutorials/850hg/p7.html
1998 S70 GLT 160K+
2005 XC90 2.5T 85K+
rspi
Postby rspi » Wed Aug 01, 2012 4:11 pm
If it's leaking, you likely need to change it. If it's not leaking, leave it alone.
'95 855 T-5R, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red
Volvo's of past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow
Donate Today - Volvo Repair Videos
Postby cn90 » Wed Aug 01, 2012 4:24 pm
rspi wrote:If it's leaking, you likely need to change it. If it's not leaking, leave it alone.
Well,
The reason I ask is that: while I am there (replacing the TB) I may as well do the Crank Seal as I don't want to do the job twice.
However, if people tell me they don't ever have a leak from the Front Cranks Seal, then I won't bother.
1998 S70 GLT 160K+
2005 XC90 2.5T 85K+
rspi
Postby rspi » Wed Aug 01, 2012 4:29 pm
Again, if it's not leaking, leave it alone. The timing belt is a 2 hour job, don't turn it into a 5 hour job messing with a seal that's not leaking. You would have to remove the crank, likely the starter, which would include the manifold, get the picture? You can do those seals and get t-boned next week. Don't fix what aint broke.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: abscate, Blockpartie, cudlob, info2x, Sommerfeldt and 32 guests
