5 speed auto trany fluid
dozzy
Year and Model: 2000 S70
Postby dozzy » Sun Feb 27, 2011 12:57 am
i have a 2000 S70 with the 5 speed automatic. i wanted to change the fluid because of it being dark in color so i called the local dealership to ask what fluid is recommended and to my luck it was the volvo specific oil that is $25 a quart! but the service manager hooked me up with a cheaper alternative. Valvoline max life DEX-MERC is compatible with the "SPECIAL" fluid requirements. the max life fluid sells for $4-$6 a qt. much cheaper than the volvo fluid. according to the dealer if your trans dip stick is short and a "B" to get to then you need the special fluid. if its regular length and easy to get to then u can use regular tranny fluid. just wanted to put this out there with hopes that it will ease the stress on pocket books when it comes time to change yours
JRL
Year and Model: Several
Flag: United States of America
Re: 5 speed auto trany fluid "READ"
Postby JRL » Sun Feb 27, 2011 3:39 am
WRONG FLUID
Just go to your neighborhood Toyota dealer and buy a case of Toyota Type IV fluid
Same stuff as the Volvo fluid (Mobil 3309) for about 5-6 bucks a quart
2000 V70R Black, 129,000 miles (Wife's R, getting up there, she won't sell it)!
2007 XC70 White/Oak over 100K perfect. New DD, sold the 06
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
FCPEURO
Year and Model: 2009 S60 2.5T
Postby FCPEURO » Sun Feb 27, 2011 4:17 pm
+1
Please tell me you did not put that fluid in your car. If you did, flush it out ASAP. That stuff will only work on the older 850 auto transmissions. The newer S70 uses the fluid that JRL mentioned above.
Jason VanGorden
Volvo Product Manager
JasonV@FCPEURO.COM
FCP Euro - European Car Parts Specialists
Quality & Service, Guaranteed for Life
155 Hill Street, Milford, CT 06460
jimmy57
Postby jimmy57 » Sun Feb 27, 2011 5:27 pm
Valvoline lists this as a Toyota T-IV and JWS 3309 fluid.
Valvoline says it works.
Volvo only did the approval on their own branded JWS 3309.
Technically Volvo does not condone use of Toyota T-IV fluids.
Who the hell REALLY knows whether it is OK or not?
Valvoline lists it as approved for a number of uses but so does Amsoil for their synthetic.
Many dealers using flush equipment are using the flush machine company's proprietary fluid with a bottle of juice added to that is supposed to be the specific additives and it is working.
I'm not too cool with ATF's that cover broad applications of fluids purportedly to be so different.
The JWS 3309 is a lower viscosity fluid and it's required additive package has a huge focus on letting the slipping lock-up torque converter function and also the previously employed neutral control work with fewer side effects. SO much for the neutral control thing.....
That service manger is probably a dealer using flush equipment that uses Valvoline's product they spec for Volvo 5 Speeds.
Oh, by the way, Volvo now has a new fluid for the 6 speeds effective 2011.
dozzy
Postby dozzy » Wed Mar 02, 2011 1:22 am
i did put the fluid in my car and have yet to see any problems. the spec. numbers on the back of the bottle matched that of the one listed in my owners manual so......... i don't see the big deal? whats all this about the JWS 3309? I have yet to come across those #'s anywhere in my manual. someone please give me the "RIGHT" answer to all this. everyones help is greatly appreciated
dozzy
Postby dozzy » Wed Mar 02, 2011 2:16 am
i have the aw50-50 5 speed and the manual says to use fluids meeting spec.1161540-8 and on the bottle of max life it shows that it meets the requirements of volvo 1161540. seems like it should be ok to me. just trying to get to the bottom of all this
cdnbluez
Year and Model: 04XC70/98 V70/99 S70
Postby cdnbluez » Wed Mar 02, 2011 4:48 am
Its simple, you need 3309 compatible, and nothing else.
1999 S70 5speed
1998 V70 SE
2004 XC70
2003 BMW 540i
1981 Chev Z28 44k miles
Previous Volvos:'01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
JRL
Postby JRL » Wed Mar 02, 2011 2:42 pm
dozzy wrote:i have the aw50-50 5 speed and the manual says to use fluids meeting spec.1161540-8 and on the bottle of max life it shows that it meets the requirements of volvo 1161540. seems like it should be ok to me. just trying to get to the bottom of all this
BTW another reason why you're reading that, 3309 was not developed in 2001-2003 which is another reason for so many failures in early 5 speeds
precopster
Year and Model: Lots
Flag: Australia
Postby precopster » Mon Mar 07, 2011 1:08 pm
I've been a member of this forum for about six months. During that time I've learned one thing:
LISTEN TO JRL
He knows his Volvos (and transmissions)
Get that fluid out of there and either put in the factory stuff or the Toyota spec stuff JRL advised on.
Current cars: 2000 V70 non turbo, 1998 V70R AWD, 2001 V70 XC project, 2001 V70 T5, 2002 XC70
What we used to own:1995 850 sedan, 1987 740 sedan, 2002 S60AWD, 1989 740 turbo wagon, 1985 760 V6, 1995 850 wagon, 1999 V70 project car.
In forum posts please call me Mike
wadew2lt
Year and Model: 2004 S60 2.5T AWD
Postby wadew2lt » Sat Mar 10, 2012 10:55 pm
cdnbluez wrote:Its simple, you need 3309 compatible, and nothing else.
So the Mobil 3309 OR the Toyota T-IV will work for my 04 S60 2.5T AWD (Calling for 1161540-8)?
I have a spec sheet from Mobiloil.com stating Mobil ATF 3309 is approved for Type T-IV, JWS 3309, GM 9986195 leading me to believe that all these will work. Am I confused?
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: abscate, Bing [Bot], KrazyKrusty, skloon, zhenya and 49 guests
