How to remove knee bolster in 1997 850 wagon
islandguy
Year and Model: 1997 850 Wagon
Postby islandguy » Wed Apr 20, 2011 3:10 am
Hello everyone,
This is my first post on this forum. I have just started to try my own wrenching on my 1997 850 wagon. The first three speeds don't work on the blower fan. I have searched the internet and found that it is likely the thermal fuse on the resistor pack. And this is normally caused by bad or dry bearings in the fan motor causing it to draw too much power, so I am going to remove the pack and motor to see what's wrong.
I have the glovy out and the lower panel off and I can see where everything is. I've read I'll need to remove the bolster to get the fan out and this looks to be the case for sure. I have removed the 3 well-discussed nuts that hold it on, but I can't get it out! It conflicts with the plastic side panels at each side and will not drop far enough to come out. The side panels seem to be part of the glove box frame and a lot of other stuff. So it looks like it would be difficault to remove them. Is there an easier way? Do the pros have any tricks?
Thanks a lot.
Glen...
tailor
Year and Model: 2004 XC90 2.5T AWD
Flag: Canada
Re: How to remove knee bolster in 1997 850 wagon
Postby tailor » Wed Apr 20, 2011 3:38 am
You really have to wiggle the knee bolster out, you will feel the threads scrape against the wholes as you pull the bolster out.
Just make sure there are not four nuts, they do seem to be at an impossible angle, a flashlight and a bit of contorting will reveal all. Grab the bolster at the ends and wiggle down, it should then come free.
tailor
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
islandguy
Postby islandguy » Wed Apr 20, 2011 4:37 am
Thanks for your reply, Tailor,
There are 4 bolts but only three have nuts. I got all 4 bolts out of the holes but the bolster is then tighly jambed against the top edges of the side panels and the bolt ends are digging into the bolster so it won't move. I can't get at the ends as they are covered by the side panels. I'll pull and bash harder tomorrow. If it is supposed to come out without removing anything else I'll get it somehow.
Thanks again.
Glen..
anjill182
Year and Model: 98 XC,98 AWD, 95 T5R
Postby anjill182 » Wed Apr 20, 2011 1:11 pm
The knee bolster disappears on the 1999 model. They put a shelf built into the panel in its place. Was something changed to allow the bolster to be removed? Sorry for hijacking.
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Postby jblackburn » Wed Apr 20, 2011 1:39 pm
I think on that side, you have to loosen the panel on the center console and drop it down a bit, and then that bolster will fall right down.
I don't remember, but it was pretty easy to get out of a 1998 S70 at least.
'98 S70 T5
2012 Chevy Cruze LT 6MT
islandguy
Postby islandguy » Wed Apr 20, 2011 2:20 pm
Thanks jblackburn, I'll see if I can get the console-side panel loose.
renns
Year and Model: Volvo V70 1998
Postby renns » Wed Apr 20, 2011 6:07 pm
I pulled mine in the 850 a couple times. It's a miserable piece, but does come out without messing with the console. Keep working at it and you should be able to find a position where it will drop free. Be sure to keep track of the exact orientation as you remove it, so the reassembly will be easier.
I think the same Volvo engineer also moonlights designing these:
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 144,000 km - daily driver
islandguy
Postby islandguy » Wed Apr 20, 2011 6:52 pm
Thanks Renns, I have to leave it for a few days. Will let you all know how it goes.
vjaneczko
Year and Model: '97 855 GLT;'06 S60R
Postby vjaneczko » Thu Apr 21, 2011 2:08 am
If you already pulled the glovebox, just reach in and smack the crap out of the bolster until it falls - it'll screech like a little old lady hittin' the nickel slots, but it'll move.
1997 855 GLT - Now for my daughter
2006 S60R - For ME!
islandguy
Postby islandguy » Mon Apr 25, 2011 8:22 pm
Thanks for all your help.
The bolster eventually came out by working from underneath, yanking hard on the inboard end and presto it was on the floor! No need to do anything to the side panels. Hopefully I will be able to get it back in!
Thanks again. I really appreciate this site and your help.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: 2forty, ashitaka695, charleskennedy23, tryingbe and 34 guests
