Fuel tank drain...
anbran
Fuel tank drain...
Postby anbran » Thu Apr 21, 2011 7:24 pm
How do you drain the fuel tank? I've tried to put a small hose down the filler pipe...Something stops it at the bottom of the neck (it seems).
1999 XC70
1998 V70
Near Guelph, Ontario, Canada
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Re: Fuel tank drain...
Postby jblackburn » Thu Apr 21, 2011 7:34 pm
Disconnect your hose at the fuel filter and jumper the fuel pump relay (103). Then let the pump do the heavy lifting.
'98 S70 T5
2012 Chevy Cruze LT 6MT
anbran
Postby anbran » Thu Apr 21, 2011 7:37 pm
Thanks...
The problem is that a line on top of the tank is leaking like crazy...hense the need for an empty tank for removal. Can your suggestion still work?
1998 V70
jblackburn
Postby jblackburn » Thu Apr 21, 2011 7:39 pm
Is it leaking at the fuel pump connection, or the EVAP hose system connection?
Follow that hose! If it's the EVAP hose, just pumping most of it out should be fine. Stop it before it runs dry though.
'98 S70 T5
anbran
Postby anbran » Thu Apr 21, 2011 7:52 pm
The fuel pump location appears dry. The XC70's fuel pump "lid" is on an angle at the front of the tank facing the back of the rear seat. The leak is "piddling" off the top back of the tank. The fuel filter is about a foot away, so its not that. Could it be a line or the EVAP? Are these both near the rear of the tank?
1998 V70
Red-Arrow
Year and Model: 850 T5 1995
Postby Red-Arrow » Fri Apr 22, 2011 2:30 am
You can disconnect the fuel rail and connect a pipe to a big drum, Just insert the key and the fuel pump will prime. It will pump all the fuel out the tank into your big drum in a few minutes. I should have done this a few days ago on my tank drop but I didn't have a big drum for the fuel.
Life would be enjoyable if it wasn't so painful to live.
anbran
Postby anbran » Sat Apr 23, 2011 12:59 am
Thanks Red Arrow...
You mention you did a tank drop...Do you have an XC70? If so, what was involved in doing that?
1998 V70
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Google [Bot], Soilworker and 39 guests
