Please don't use image hosting services like Image Shack. Here's why.
Having trouble logging in? Please delete http://www.matthewsvolvosite.com cookies in your browser. Here's how.
wet carpet on driver side?
tkende06010
Year and Model: 850glt,1996
Postby tkende06010 » Sun May 08, 2011 3:40 pm
Hi all, moving on to the next issue with my 96 Volvo 850 N/A, The car has been in the garage for about 4 weeks now while I have done various repairs. The carpet in front and back on driver side mostly, is wet. I did not run the car for about 5 days, and it started to dry up so I figured it had gotten wet outside somehow, but after fixing pcv system and running the car to check it, I noticed the floor was wet again. When I rub my hand on it, it feels oily, and I suspect it may be the heater core leaking? I have not really noticed the coolant going down, but I have not driven the car at all for 2 months, so it may not have had a chance to go down noticeably? Anybody with input? i looked for a tutorial on this, but can't find anything for the 850. Thanks
ecbsykes
Year and Model: 2000 V70XC
Flag: United States of America
Re: wet carpet on driver side?
Postby ecbsykes » Sun May 08, 2011 3:54 pm
Heater core for sure!
A lot of write-ups for the the S/V70 series, but I'm pretty sure the 850 is nearly identical.
http://volvospeed.com/vs_forum/topic/97 ... e-install/
Ed Sykes
2000 V70XC 2.4L Emerald Green 236,000 miles
tkende06010
Postby tkende06010 » Sun May 08, 2011 4:59 pm
thanks for the input, if I stuff my head under the dash, I can see a bit of a white plastic box, which I think the core is in.
Fish stick88
Year and Model: 1994 - 850 Sedan
Postby Fish stick88 » Sun May 08, 2011 5:35 pm
thats right. I had the same problem too.. make sure to check all of your drains too, they could be clogged
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
brownslanejag
Year and Model: 960 1995
Postby brownslanejag » Sun May 08, 2011 5:42 pm
How about for the 1995 960? My core is leaking. And the shop wants 1500.00 bucks to fix it. They say that the whole dash has to come out? And where is it on the 960?
Fish stick88
Postby Fish stick88 » Sun May 08, 2011 7:50 pm
the whole dash does have to come out, unless you want to cut apart your car to get to it. its a tricky fix, and it depends on where its leaking 850's ahve the easiest core to replace, it should be similiar on your 960. Try looking up "960 Dash Removal" in the repair database, should show something.
FCPGroton
Year and Model: 2004 S60R
Postby FCPGroton » Sun May 08, 2011 10:21 pm
Common symptom of heater core failure. I have the OEM Nissens unit for it available below, is a bit tedious to replace on your model (as previously stated, dash has to come out for access). But not as bad when it comes down to the work itself, you should also check your hoses and the small o-rings leading to the coupler at the firewall. Something that is often overlooked and could cause future leaks.
http://www.fcpeuro.com/products/volvo-h ... 70-s70-v70
I know replacing the core kinda sucks, but I hope this helps!
Jason VanGorden
Volvo Product Manager
JasonV@FCPEURO.COM
FCP Euro - European Car Parts Specialists
Quality & Service, Guaranteed for Life
155 Hill Street, Milford, CT 06460
ecbsykes
Postby ecbsykes » Sun May 08, 2011 11:21 pm
Don't forget to replace the o-rings too!
Ed Sykes
tkende06010
Postby tkende06010 » Mon May 09, 2011 12:37 pm
Thanks guys, I am going to take it out in the next day or two, I will let everyone know how it goes, and I will get some pictures too
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: dyn blin, Google Adsense [Bot], Matty Moo, polskamafia mjl and 40 guests
