Please don't use image hosting services like Image Shack. Here's why.
Having trouble logging in? Please delete http://www.matthewsvolvosite.com cookies in your browser. Here's how.
How does the oil cooler system work?
ecbsykes
Year and Model: 2000 V70XC
Flag: United States of America
Postby ecbsykes » Tue Jun 21, 2011 3:47 pm
I've had this question burning in my mind for a long time, and a recent thread has pushed me to figure it out. Can someone explain the entire system for me (and rest of the forum)?
What I know is this:
-There is the unit that is attached the the oil pan, and the two small hoses that go to it have coolant in them.
-Inside the oil pan are some tubes (not main pickup) that go somewhere containing what? coolant?
-Oil is pumped through two hoses to the radiator to be cooled, these contain oil, not coolant. Is this related to the oil cooler unit (with coolant) on the back of the pan?
Thanks!
Ed Sykes
2000 V70XC 2.4L Emerald Green 236,000 miles
mrscullini
Year and Model: 05 XC70, 08 XC70
Re: How does the oil cooler system work?
Postby mrscullini » Tue Jun 21, 2011 4:25 pm
it appears the unit is a small heat exchanger. from what i can tell, oil is pumped through ports that are on the mating surface with the oil pan. see this link,
http://www.partsgeek.com/catalog/2001/v ... ooler.html
i'm hoping this is my problem. sure seems a lot easier to replace this than a head gasket. also, this seems like a more servicable design than the oil cooler integrated into the rad.
jimmy57
Postby jimmy57 » Tue Jun 21, 2011 4:58 pm
it is a parallel plate cooler. It is configured as though you took a radiator and sealed the finned area where air normally passes and pushed oil through the radiator. Of course, now the radiator coolant absorbs heat instead of giving up heat. The oil from oil pump passes through filter and then goes through oil cooler before returning to go to crank, cams, turbo.
The coolers integrated in tank of radiator work this way too with a little modification. Those have the oil going through a mini radiator that sits in the hot end of radiator. Auto trans cooler gets the cold end.
jblackburn
Year and Model: 1998 S70 T5
Postby jblackburn » Tue Jun 21, 2011 5:04 pm
Do these also have some sort of oil thermostat to control when oil does/doesn't go through the cooler like the 1998-earlier models do?
'98 S70 T5
2012 Chevy Cruze LT 6MT
fields 100
Year and Model: s 60 T-5
Postby fields 100 » Tue Nov 01, 2011 1:28 am
jimmy57 wrote:it is a parallel plate cooler. It is configured as though you took a radiator and sealed the finned area where air normally passes and pushed oil through the radiator. Of course, now the radiator coolant absorbs heat instead of giving up heat. The oil from oil pump passes through filter and then goes through oil cooler before returning to go to crank, cams, turbo.
So, if this is closed, no fins exchanger, the oil, in the beginning of the engine operation, is being warmed up (not cooled) by the coolant which heats up much faster than the engine oil. The thermostat, I believe, is just a plunger and a spring, that allows the oil circulate through the heat exchanger while it is cold and thick, and then, when the oil loses some viscosity during warm up, the plunger closes and there is no more circulation through that heat exchanger in the radiator. I think it makes sense as it keeps condensation from the intercooler down to the minimum during short urban trips in the cool weather.Just my theory.Any opinions?
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: charleskennedy23, Herb Goltz, northern_dweller, sleddriver and 32 guests
