Location of Coolant Temperature Sensor
sealuva
Year and Model: S70 1998
Postby sealuva » Mon Aug 15, 2011 5:17 pm
Can someone show me with a picture of where this is located. I saw one on this site somewhere but the picture was horrible. 1998 S70
Location and picture. Thanks all. :)
jblackburn
Year and Model: 1998 S70 T5
Flag: United States of America
Re: Location of Coolant Temperature Sensor
Postby jblackburn » Mon Aug 15, 2011 5:18 pm
Thermostat housing right by the power steering pump. CTS is the brass plug you see here.
'98 S70 T5
2012 Chevy Cruze LT 6MT
sealuva
Postby sealuva » Mon Aug 15, 2011 5:22 pm
Is it as easy as unscrewing it and taking it out and plugging in a new one? I want to change both the thermostat and this part. Thanks
jblackburn
Postby jblackburn » Mon Aug 15, 2011 5:28 pm
You'll need to drain a bit of coolant first. Probably a good time to change it (should really be done every 3 years or so).
http://www.matthewsvolvosite.com/2009/0 ... 0-or-xc70/
'98 S70 T5
sealuva
Postby sealuva » Mon Aug 15, 2011 5:37 pm
Do I need to drain this for just the sensor or just to change the thermostat? Also is it as easy as unscrewing it and screwing in the new one? Thanks again for all your help.
jblackburn
Postby jblackburn » Mon Aug 15, 2011 5:40 pm
The Torx bits on the housing can be a real pain to get out. Spray both of them over the next few days with lots of PB Blaster and hopefully they should come right out.
Dealers, if they're close by, sell new bolts that are metal instead of the crappy aluminum they used for the ones probably still in there.
The coolant level will need to be lowered before you open up the thermostat housing or you'll spill it everywhere. Thermostat housing needs to be removed to really get access to the CTS plug on a 1998 model - then yes, just unscrew the old and and screw the new one in. Take a look at that link above.
'98 S70 T5
Year and Model: Many Volvos
Postby Ozark Lee » Mon Aug 15, 2011 5:44 pm
As Justin said, you will need to remove the upper portion of the thermostat housing to get to it and you should drain some coolant before you remove the cap. I remove the lower radiator hose and drain out 1/2 gallon or so. I would advise not using the drain cock since it is prone to breaking at the the base of the radiator.
'99 V70XC - Nautic Blue
sealuva
Postby sealuva » Mon Aug 15, 2011 6:13 pm
Thanks everyone.
mike walter
Year and Model: 1995
Postby mike walter » Mon Aug 15, 2011 6:40 pm
The torx bolts can be a bit tight. Let the engine warm up, loosen slightly, not enough to allow coolant to escape.I install a clamp on the hose leading to the block from the over flow box and pull the box out of the mounts and lay it behind the engine. You will loose very little coolant this way.
seth1991
Year and Model: V70, 1999
Postby seth1991 » Wed Dec 07, 2011 12:28 am
Sorry to revive this thread, and I've bumped a thread of my own, but are the steps listed for the 98 V70 the same as for a 1999? My CEL is on with the code P0118, which I believe to be the ECT Sensor failure code. I just wanted to make sure before I buy the part [also replacing the thermostat]. Thanks!
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot], MSNbot Media and 24 guests
